Using the OBD Link MX+
NickAtNight
Nicholas James
LaPlace La
Bronco Sport Heritage 2023
Learning how to use my new OBD Link MX+
Ford Bronco Sport Using the OBD Link MX+ IMG_1119
NickAtNight
NickAtNight
Nicholas James
LaPlace La
Downloaded the FORscan Lite app for iOS.
I was looking for the command do display what gear I was in. I could not figure it out with the OBD Link software.
With the FORscan dashboard I found these five displays:
Transratio
TGE
Gear_Cmd
Gear
In_Gear
looks like the Gear and Gear_cmd are the two options to try.
Ford Bronco Sport Using the OBD Link MX+ IMG_1102
NickAtNight
NickAtNight
Nicholas James
LaPlace La
My first OBDLink dashboard.
- from the FordLincolnMercury menu
- to the Powertrain Control Module
- searched for Gear
Selected the Gear Commanded option.
The rest of them are the standard SAE PID’s. (At least the first 21. Think there are 39)
seems like everything worked. I was connected to the General network. The Gear is on the A network, so I didn’t think it would read that on General.
Ford Bronco Sport Using the OBD Link MX+ IMG_1116
NickAtNight
NickAtNight
Nicholas James
LaPlace La
I set up the logging to generate a CSV file every second. That was for all the SAE PIDs and a handful of the Powertrain PIDs.
Looks like “Transmission Gear Engaged” shows the gear we are actually in. While “Gear Commanded” is what is being requested.
Values:
70. Park
60. Reverse
50. Neutral
1. Drive first gear
3. 3rd gear
4. 4th gear
5. 5th gear
Did not get on highway so the higher gears did not show.
Did not see any second gear.
In reverse (60), gear engaged showed 128 and 130.
NickAtNight
NickAtNight
Nicholas James
LaPlace La
UPLOAD files:
To upload the CSV files automatically:
On the Settings menu.
Under Preferences
Select Sync
- activate ICloud Sync CSV log files
Or
Login to your Dropbox if you use them.
I will stay with iCloud for now.
1. it created a OBDLink folder.
2. Within that folder is a CSV logs folder.
(Means the other features like diagnostics will be uploaded to different filders)
3. Then there is a folder that looks like my VIN. Guess that is for if we are using the link with multiple vehicles !
4. And then we get to the CSV files.
Note: CSV stands for Comma Separated Values. It is easy to read and can be opened with any Spreadsheet like Excel or Numbers
Ford Bronco Sport Using the OBD Link MX+ IMG_1120
NickAtNight
NickAtNight
Nicholas James
LaPlace La
What to LOG?
That has to be setup also.
Select setrings
Then select preferences
Then select Logging
1 Turned on logging
2. Set for a fixed time interval
3. Set time at 1 second
4. Then we have to select the PID’s to record (stands for Parameter ID). So select that.
5. Then we drown in choices!
there are 8 groupings.
For this test, I selected all 69 of the SAE (Society of Automotive Engineers) default PID’s
NOTE: The Ford/Lincoln/Mercury option may not show. This was a custom add in they sell. It was free with the device
Think that was
1. settings
2. Get Enhanced OEM Add-Ons
3. Select Ford Lincoln Mercury
4. select Ford 2023 Enhanced Diagnostics
BUT… It might have been inder
1. Settings
2. User Defined PID’s
I also Selected 26 Power Control Module in the Ford Mercury Lincoln addons (all under Powertrain Control Module. It appears to be more because each group has some common file like VIN)
thus selected a number of general items in all the other A network groups.
A I believe is the High Speed Network
B I believe is the Medium Speed Network
When we connect, it appears we can only connect to either the SAE, the A or the B network at a time.
In this test I was connected to the SAe, and it seems to have read the A network at the same time.
Ford Bronco Sport Using the OBD Link MX+ IMG_1128
Ford Bronco Sport Using the OBD Link MX+ IMG_1129
Ford Bronco Sport Using the OBD Link MX+ IMG_1130
Ford Bronco Sport Using the OBD Link MX+ IMG_1123
Ford Bronco Sport Using the OBD Link MX+ IMG_1124
Ford Bronco Sport Using the OBD Link MX+ IMG_1125
Ford Bronco Sport Using the OBD Link MX+ IMG_1126
Ford Bronco Sport Using the OBD Link MX+ IMG_1127
NickAtNight
NickAtNight
Nicholas James
LaPlace La
The Map feature looks nice.
This was my first trip with the OBD installed.
It only recorded MPH in my initial setup.
Ford Bronco Sport Using the OBD Link MX+ IMG_6551
NickAtNight
NickAtNight
Nicholas James
LaPlace La
Sample log file.
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950515253545556575859606162636465666768697071727374757677787980818283848586878889909192939495
Time (sec)Fuel system 1 statusFuel system 2 status Calculated load value (%) Engine coolant temperature (°F)Short term fuel % trim - Bank 1 (%)Short term fuel % trim - Bank 3 (%)Long term fuel % trim - Bank 1 (%)Long term fuel % trim - Bank 3 (%) Intake manifold absolute pressure (inHg) Engine RPM (RPM) Vehicle speed (MPH)Ignition timing advance for #1 cylinder (deg) Intake air temperature (°F) Absolute throttle position (%) Location of oxygen sensorsO2 voltage (Bank 1 Sensor 2) (V)Short term fuel trim (Bank 1 Sensor 2) (%) OBD requirements to which vehicle or engine is certified Time since engine start (sec) Distance traveled while MIL is activated (miles) Fuel rail pressure (psi) Commanded evaporative purge (%) Fuel level input (%) Number of warm-ups since DTCs cleared Distance traveled since DTCs cleared (miles) Barometric pressure (inHg)O2 sensor lambda wide range (current probe) (Bank 1 Sensor 1)O2 sensor current wide range (Bank 1 Sensor 1) (mA)Catalyst temperature (Bank 1 Sensor 1) (°F) Control module voltage (V) Absolute load value (%) Fuel/Air commanded equivalence ratio Relative throttle position (%) Ambient air temperature (°F) Accelerator pedal position D (%) Accelerator pedal position E (%) Commanded throttle actuator control (%) Fuel typeEvap system vapor pressure (inH2O)Long term secondary oxygen sensor trim bank 1 (%)Long term secondary oxygen sensor trim bank 3 (%) Engine fuel rate (gal/hr) Actual engine - percent torque (%) Engine reference torque (lb•ft)Intake air temperature bank 1 sensor 1 (°F)Intake air temperature bank 1 sensor 2 (°F)Intake air temperature bank 1 sensor 3 (°F)Intake air temperature bank 2 sensor 1 (°F)Intake air temperature bank 2 sensor 2 (°F)Intake air temperature bank 2 sensor 3 (°F) Engine friction - percent torque (%) WWH-OBD vehicle cumulative continuous MI counter (hr) Engine Fuel Rate (lb/min) Vehicle Fuel Rate (lb/min) Engine Exhaust Flow Rate (lb/min)Fuel System A Use Percentage Bank 1 (%)Fuel System B Use Percentage Bank 1 (%)Fuel System A Use Percentage Bank 2 (%)Fuel System B Use Percentage Bank 2 (%)Fuel System A Use Percentage Bank 3 (%)Fuel System B Use Percentage Bank 3 (%)Fuel System A Use Percentage Bank 4 (%)Fuel System B Use Percentage Bank 4 (%)Evap System Vapor Pressure A (inH2O)Evap System Vapor Pressure A (wide range) (inH2O)Evap System Vapor Pressure B (inH2O)Evap System Vapor Pressure B (wide range) (inH2O) Evap System Sealing Status Vehicle Odometer Reading (miles) Diagnostic Specification Version Vehicle Manufacturer ECU Software Number Vehicle Identification Number Global Real Time (min) Total Distance (miles) Vehicle Speed - High Resolution (MPH) Engine RPM (RPM) Vehicle Speed Sensor (MPH) Air Filter Monitor status - Remaining life of engine air filter (%) Air Filter Monitor status - Distance traveled since successful monitoring of the air filter (miles) Manifold Absolute Pressure Sensor Voltage (V) Fuel Systems Information - Closed Loop Fuel Control Fuel Rail Pressure Sensor (V) Barometric Pressure - Corrected (inHg)Oxygen Sensor Bank 1 Sensor 1 (O2S11) Heater Current Monitor (A)Oxygen Sensor Bank 1 Sensor 2 (O2S12) Heater Current Monitor (A) Barometric Pressure Sensor (V) Engine Cooling Fan Speed - Desired (%)Intake Air Temperature Sensor 2 (°F) Fuel Rail Pressure - Desired (inHg) Knock Control Spark Retard (deg) Fuel Temperature A - Raw (°F) Powertrain Drive Mode - Actual Total Spark Advance (deg) Gear Commanded Transmission Gear Engaged
2.0052252.94117789.6-7.812501.5625026.577091330.750-18.580.634.50980431.27599.218753002921.0600000000001.07710750000000001.2548171000000000000000000000000000000000000000000000000000700
3.0012252.94117789.6-7.812501.5625026.577091330.750-18.580.634.50980431.27599.218753002921.0600000000001.07710750000000001.2548171000000000000000000000000000000000000000000000000000700
4.0012252.94117789.6-7.812501.5625026.577091330.750-18.580.634.50980431.27599.218753002921.0600000000001.07710750000000001.2548171000000000000000000000000000000000000000000000000000700
5.0012252.94117789.6-7.812501.5625026.577091330.750-18.580.634.50980431.27599.218753002921.0600000000001.07710750000000001.2548171000000000000000000000000000000000000000000000000000700
6.0022252.94117789.6-7.812501.5625026.577091330.750-18.580.634.50980431.27599.218753002921.0600000000001.07710750000000001.2548171000000000000000000000000000000000000000000000000000700
7.0022249.8039291.4-9.37502.34375027.1676921313.750-1680.632.5490231.27599.2187532402903.6555036.07843411664.032129.8254010.992409-0.0546875782.613.56262.74511.099128517.64705873.415.6862757.843137319.21568710.032117046-0.7812501.201982737188.0783580.680.6000012190.1137780.1137781.712551467.8431432.15686400000000.03211704600016345.169400953094.716345.1690133206553440721.5621.222656213.284457430.046877004.0371456080.67373.666080.684370-6.57070
8.0012249.8039291.4-9.37502.34375027.1676921313.750-1680.632.5490231.27599.2187532402903.6555036.07843411664.032129.8254010.992409-0.0546875782.613.56262.74511.099128517.64705873.415.6862757.843137319.21568710.032117046-0.7812501.201982737188.0783580.680.6000012190.1137780.1137781.712551467.8431432.15686400000000.03211704600016345.169400953094.716345.1690133206553440721.5621.222656213.284457430.046877004.0371456080.67373.666080.684370-6.57070
9.0012249.8039291.4-9.37502.34375027.1676921313.750-1680.632.5490231.27599.2187532402903.6555036.07843411664.032129.8254010.992409-0.0546875782.613.56262.74511.099128517.64705873.415.6862757.843137319.21568710.032117046-0.7812501.201982737188.0783580.680.6000012190.1137780.1137781.712551467.8431432.15686400000000.03211704600016345.169400953094.716345.1690133206553440721.5621.222656213.284457430.046877004.0371456080.67373.666080.684370-6.57070
10.0142249.8039291.4-9.37502.34375027.1676921313.750-1680.632.5490231.27599.2187532402903.6555036.07843411664.032129.8254010.992409-0.0546875782.613.56262.74511.099128517.64705873.415.6862757.843137319.21568710.032117046-0.7812501.201982737188.0783580.680.6000012190.1137780.1137781.712551467.8431432.15686400000000.03211704600016345.169400953094.716345.1690133206553440721.5621.222656213.284457430.046877004.0371456080.67373.666080.684370-6.57070
NickAtNight
NickAtNight
Nicholas James
LaPlace La
BRONCO SPORT HERITAGE TIRES: Estimate of revs/mile
Width225mm
Ratio65%
Wheel Size17in
Tire Width8.9in
Sidewall5.8in
Tire Height28.5in
Tire Circumference89.6in
Revolutions per mile707.3rpm
NickAtNight
NickAtNight
Nicholas James
LaPlace La
For the test drive. Normal mode.
Gear 1: 0 to 8 MPH
Gear 2: ~8 MPH (rare)
Gear 3: 8 to 14 MPH
Gear 4: 14-17 MPH
Gear 5: 17 to 20+ MPH
Engine speed was maintained between 1,000 and 2,000 RPM.
Ford Bronco Sport Using the OBD Link MX+ Screen Shot 2024-11-02 at 12.34.47 PM
NickAtNight
NickAtNight
Nicholas James
LaPlace La
Today's test drive. Mostly SPORT mode.
GEARMPHSPORT MPH
10-80-10
2~8na
38-1410-19
414-1719-24
517-20+24-44
6not tested43-47+
7not testednot tested
8not testednot tested
Engine speed was maintained between 2,000 and 2,200 RPM.
Note: Mostly just learning how to use the UBDLink.
Ford Bronco Sport Using the OBD Link MX+ Screen Shot 2024-11-03 at 2.55.21 PM
NickAtNight
NickAtNight
Nicholas James
LaPlace La
Quick look at Instant MPH versus speed.
Ford Bronco Sport Using the OBD Link MX+ Screen Shot 2024-11-03 at 3.25.48 PM
