- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,733
- Reaction score
- 13,152
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
There's a difference between Ace Hardware store hose and the fuel/fire resistant hoses used in modern automotive manufacture.I suggested on another post that it's a hose that they could probably get at Ace Hardware.
You gotta know your materials. This isn't typical Loctite thread sealant you might have in your garage toolbox. It's Loctite 638, which is a "retaining compound." It's designed for just this purpose.It's not even threaded, and you cover it with loctite and push it into an existing hole in the engine. I'm amused to the point of a "Face Palm" reaction. Loctite in a hole where gas could be flowing ? ? ?
This is the kind of overblown, speculative comment that doesn't add anything to understanding. I get that you might feel this way, but it would be of much more service to your fellow forum members if you had some evidence to back up your feelings.Oh and it runs down to a pre-existing hole on a bracket at the bottom of the engine. You could easily get the impression that it was already supposed to be there, and they figured they'd save 50 cents and not include it on a million vehicles.
Yes, working on modern engines can be a complicated endeavor. You probably shouldn't be mucking around under the hood unless you know what you're doing.f you watched the video, the battery has to be removed to install this Perfect(?) fix for another quality Ford part. OK - I'm being dramatic, but this Hare brained fix requires pulling the battery and battery tray, and this is no easy activity. There's multiple wires and harnesses that have to be unbolted and pried loose, or cut loose from miscellaneous attachments. Putting it all back in place just begs for mistakes crimped wires or who knows.
I wish I could help you there. This is one of those issues that requires the diagnostic tools only available at a Ford service department. Anyone looking for a new car should keep this in mind when shopping; after-purchase service should be a factor in your purchase decision. If you don't have a dealership near you that you trust to help with problems like this then you might want to look at a different brand.OK _ I'm still waiting. Does anyone have an explanation why voltage would drop on acceleration, and climb while idling ? ?
Somehow, I think not...Drama class is over
