- First Name
- Tom
- Joined
- Jun 7, 2021
- Threads
- 37
- Messages
- 867
- Reaction score
- 1,068
- Location
- Los Angeles Metro
- Vehicle(s)
- 2021 Bronco Sport
- Thread starter
- #1
This update includes new maps and updated Gracenote version. To get this update use the following link:
https://www.ford.com/support/sync-maps-updates/
This is a large download to your Windows device or your Mac. Make sure you have a fast reliable connection. It may take over an hour to complete. Make sure your device does not go into sleep mode. FOLLOW INSTRUCTIONS.
You will need a USB-A or USB-C flash drive that is 16GB or larger. The flash drive will need to be reformatted to exFAT.
FOLLOW INSTRUCTIONS and copy files to USB flash drive. This may take up to an hour.
We are now at 2 hours.
Time to update the vehicle. This will take an additional hour. Plan when taking a long drive. The vehicle must be running the entire time.
Remove any USB cables from the ports.
If you are experiencing any of the Sync 3.4 Build 22251 issues like rwdata, you will need to do the following. (If you are not experiencing any of the Build 22251 issues, go ahead and insert the flash drive and follow instructions.)
Note: This will clear all your SiriusXM stations saved. You will need to save them again.
Press and hold the volume/power button and the seek/forward button on the head unit. Do not release for 2 minutes. The screen will go black and restart many times.
Go to your iPhone or Android phone and open FordPass app. Deactivate the vehicle from FordPass.
After 2 minutes, let the screen come back to life. Go to settings and remove any phones paired via Bluetooth. Go to Apple CarPlay settings and remove any devices. Go to Android Auto settings and remove any devices.
Under Settings, General: Press Reset, Master Reset. Let the head unit restart.
Insert the flash drive in the ports under the climate controls. FOLLOW ON-SCREEN INSTRUCTIONS
Do not remove the flash drive. Do not turn off the engine.
This will take around an hour to complete.
My Nav Maps are now NA 2 22
I came up with this procedure after experiencing the MEM_ERR03 error.
This update will not update Sync 3.4 to a later build. As far as I can tell, this update does not correct the rwdata issues. We are still looking forward to a new build of Sync 3.4 to be released directly from Ford.
