Speedometer Calibration With Larger / Bigger Tires?
MattH88
Matt
Seattle
I've seen this tossed around before on the boards, but haven't actually seen if anyone has had their speedometer re-calibrated after getting some bigger shoes.
If you've done it, would you mind explaining how that process went for you? Service dept out here closed on Sunday, so I'm hoping one of you can share some wisdom on whether or not it's a quick/easy fix. Thanks!
Zolutar
Trevor
Sea to Sky, BC, Canada
to recalibrate, it would have to be done at the dealer at this point.
Forscan has not cracked the BdyCM Central configuration yet, once they do, it can be DIY.
DakotaTimber
DakotaTimber
North Dakota
BS BL + BL, 360+, tow +
I doubt they will let that get cracked for DIY. Basically it lets you alter the miles on the car you get a marked title.
Zolutar
Trevor
Well, it is a configurable option for other Ford models, and thus likely, but will be awhile
MattH88
MattH88
Matt
Seattle
My dealer actually said they couldn’t do it, and referred me to a commercial spot.
Zolutar
Trevor
I can see where abuse of this setting could lead to fraud and thus not something Ford would admit to being able to do.
Mike_L
Guam
What about a separate module? When I increased tire size on my Taco, the Toyota Custom Shop installed a separate module to correct the speedometer.
From 225 65R17 to my new 235 65R17 per calculators I found through google at exactly 60 mph on the 225 I’ll be doing 61.1 on the 235. I looked up the 245 65R17 and it was I think 61.7 mph..
Not enough to worry with.
These small increases won’t mess up suspension geometry or cause antilock braking timing problems.
And should not increase strain on the suspension or throw off transmission gear ratios enough to cause problems.
I’m only going up to 235 because I’ve got the 1.5L engine and I don’t want to give up any acceleration rates from a stop.
I think my small increase adds 4 pounds to each tire as it is.
So 4 pounds each tire x 4
16 pounds of additional rotational mass has the same effect on acceleration and deceleration as 32 pounds of static ( unsprung ) mass.
https://www.broncosportforum.com/forum/threads/yokohama-geolandar-a-t-g015.4229/post-72625
rdc17
VA
Bronco Sport Badlands
Has anyone tried this with Forscan 2.4.4 beta?
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
Have you thought about teaching math, physics or engineering? :crackup: :crackup::clap:
