Road Noise
Mikemmm51
My 2021 BS BB has a loud low pitched whistle. Almost sounds like it’s coming from my sunroof but it’s closed. Happens above 70mph. Anyone else have a sunroof and notice this? Is it maybe coming from somewhere else?
Deleted member 6350
Sorry Mike no whistle from mine, cruise is usually set at 75.
P.S. have you tried to crack it open or is that gonna be to noisy ?
Did you see these moonroof posts? If these aren’t your specific noise issue you can search for moonroof on this forum for others.
https://www.broncosportforum.com/forum/threads/moonroof-front-edge-rubber-seal-coming-off.8713/
https://www.broncosportforum.com/forum/threads/new-recall-by-nhtsa-for-bronco-sport-moon-roof.4135/
And .. don’t know if you have a roof rack but often noises results from wind hitting or passing over the roof rack. (Obviously huh)
metalbender
Fred
Sask. Canada
I attribute my whistle to the magnetic mount antenna. Seems to depend on wind direction. Mine is very subtle, barely audible.
Hi there! Go ahead and send us a private message with your VIN and the name and location of your Ford dealer, and I’ll look into this whistle noise. Thanks!
Mikemmm51
That’s in the back right? This sound is coming from the front.
metalbender
Fred
Sask. Canada
My CB antenna is in front of the roof rack. The noise seems to be from the top center.
FYI, Ford was asking for a DM, not a direct reply to their post. Use the envelope next to the bell in the banner at the top. Hit the “start conversation button” and put @Ford Motor Company as the recipient.
I made a roof rack for my truck, and it made a horrible noise until I taped the ends of the pipes. Check to make sure you don't have a missing end cap somewhere.
I would temporarily tape around the seam on the sunroof to confirm it isn't coming from there.
Mikemmm51
Thanks. I’ll try.
Mikemmm51
I did but it was quoted and shows up in the quote.
