remove screws from behind screen
gailey4
Andy
Clinton, TN
to rmove the screws from area behind screen on BS use a security T30 torx. This is commonly known as a Bronco Screw. I am going to mount a Bulletpoint Rubigrid in the area. which I will install a ham (2 way) radio. No holes drilled
Actually, if we are being 100% honest, while yes, a Torx works, they’re actually Torx plus.
Timon.Arg
Sebastian
Argentina
www.qrz.com
Bronco Sport 2026
Just to share... No need the Bulletpoint Rubigrid... Just 2 RAM MOUNTS, 1 inch ball RAM Mount.
One for Phone and/or universal camera (goPro, etc). the otherone
Ford Bronco Sport remove screws from behind screen 1782222872626-22
Ford Bronco Sport remove screws from behind screen 1782222896483-d3
Another configuration
Ford Bronco Sport remove screws from behind screen 1782226624811-vv
gailey4
Andy
Clinton, TN
It is actually a security torx T30. A regular torx will not work.
that tray is actually called an accessory tray.
gailey4
Andy
Clinton, TN
Looks great. I still have some thoughts for my self. Where is the best/easiest place to mount the radio, not the head the main part, and how did you do the wiring to the head?
Ford Bronco Sport remove screws from behind screen IMG_1442
I’m very confused. Are you implying I’m wrong? Because I’m not.
From Google:
Removal/Install Tool: Factory trim and accessory tray brackets are usually secured using Torx Plus (TP).
So, again… as I stated earlier… while a Torx bit WILL work, it’s not the right tool for the job. Try removing a torqued down TP bolt with a regular Torx and you will very quickly realize the difference.
https://www.powertooljoy.com/torx-plus-vs-torx-bits/
Timon.Arg
Sebastian
Argentina
www.qrz.com
Bronco Sport 2026
Thanks! I’m actually planning to improve the installation quite a bit soon, and once I do, I’ll make a proper post in the group with more details and photos.
For now, I have the main radio body mounted under the driver’s seat.
The power wires come directly from the battery, pass through a rubber grommet near the steering column, behind the brake pedal area, then run behind the lower trim along the driver’s door sill and end up under the driver’s seat.
Ford Bronco Sport remove screws from behind screen 1782300747666-n2
Ford Bronco Sport remove screws from behind screen 1782300782762-96
Ford Bronco Sport remove screws from behind screen 1782300823081-71
From the inside.
Ford Bronco Sport remove screws from behind screen 1782300845755-5o
Ford Bronco Sport remove screws from behind screen 1782300887030-gk
Ford Bronco Sport remove screws from behind screen 1782300986541-rs
From the back of the driver seat.
Ford Bronco Sport remove screws from behind screen 1782301003672-kx
From there, the UTP/control cable goes from the main unit to the head unit. That is currently the part I’m not fully happy with: the cable runs visibly through the center console up to the accessory tray, where I currently have the head unit mounted.
EXAGERATING THE PATH....
Ford Bronco Sport remove screws from behind screen 1782301085808-qt
My next plan is to redo that part. I want to mount the head unit in the overhead sunglasses holder area, then route the UTP/control cable above the headliner, down the A-pillar, and back down toward the area under the seat.
For the microphone, I’m also planning to install a panel-mount connector, so the mic can plug in cleanly while the cable remains hidden and routed back to the main radio body.
I hope this helps.
gailey4
Andy
Clinton, TN
From Google:
security torx is a torx plus tp from what I understand from the internet. My FORD dealer told me to get a security torx
From the inside.
I hope this helps.
From the inside.
I hope this helps.
Thank you for all your help. I am N9PNL
My 25 BS BL has the nipple . Ford did change the type of torx.
Odd, mine was a Torx plus.
Torx plus and security Torx are not the same. Wonder why yours has a different bolt.
Must be a Friday build.
