Recommended Jack Stand Placement?
BabyBB
Gary
CO
VW, Tesla
What are the recommended jack stand placement areas for the Bronco Sport?
I see the jacking points - need recommended spots for placement of jack stands.
Thanks
ScareCrow
Burl
Indiana
BS/Badlands
Thanks
Here is one location anyway........
Ford Bronco Sport Recommended Jack Stand Placement? 0_lede-copy
Ford Bronco Sport Recommended Jack Stand Placement? 2021-Bronco-lift-points-350x823
I've used the solid pinch points with great success. Had the entire vehicle up on four stands no issues at all working on the oil, tire rotation, etc
BabyBB
Gary
CO
VW, Tesla
Thanks - that was my go to
If you are using the "solid pinch points" for the jack stands, then where are putting the jack?
I haven't needed to put the rear of the vehicle on jack stands yet, but I used the frame just inboard of the lower A-arms for the front.
Marco
Marco
San Diego
So where did you lift with your floor jack when utilizing 4 jack stands?
When I need it up on 4 jack stands, I use the front pinch point as a jack point, the rear pinch point for the jack stands in the back, and then the subframe just inside the A-arms for the front.
kshaw
Kent
Gaithersburg, MD
I realize that this is an old thread, but I found these jack stands that can use your trolley jack to put the jackstand at the same location as your jackpoint. Height is adjustable. These are on sale now but still a little pricey. I haven't tried them yet on the BS but they do look promising.
https://www.etamfg.com/shop.html?store-page=Rennstand-Each-1-Piece-p252276669
