RDU problem I think.
warpig
Louisiana
So my 2021 First Edition is making a grinding noise at times. I never use 4 wheel drive but have been hearing a slight grind at times coming from under the car. I decided to put it in 4wd and going strait there is no noise. When I turned left it went to grinding pretty bad. Went back to 2wd and turns are okay.
I am assuming this is a RDU problem and I need to bring it in. I have the ESP warranty thankfully. Does this service bulletin pertain to my vehicle? TECHNICAL SERVICE BULLETIN Chatter/Shudder During Low Speed Turning Events 25-2351
I ask because I read somewhere that the FE and Badlands may have a different type of RDU as stated in the bulletin. From the SB, Vehicles equipped with a single active torque RDU only.
V8 Yankee
Harold
Miami
21 Bronco Sport
The 2.0 engine models have the dual clutch. The 1.5 Outer Banks have the single clutch RDU. My RDU was replaced while under warranty as well as the left axle. Since then I replace the fluid every 25 to 30 k, super easy job as long as you have ramps for all fours and a creeper. These RDUs are notorious for problems so regular fluid changes are highly recommended. Especially when out of warranty.
warpig
Louisiana
Thanks for the reply. Do you know if there is a service bulletin on the dual clutch system? That is a bummer that Ford built the system to fail so easily.
Whpony96
Scott
Nampa, Idaho
What are your current miles on the OD and did you have the RDU serviced since you bought it?
warpig
Louisiana
Miles are around 34000 and no never did have it serviced. 34000 miles and you need to service the rdu. Really Ford dropped the ball. My 2 cents anyway. Problem I do not trust any of the dealers in my area to do the work correctly.
Thanks for the TSB
V8 Yankee
Harold
Miami
21 Bronco Sport
Servicing the RDU is very easy. Just ensure you use Motorcraft RDU oil, one quart is more than enough. It contains a special additive and will ensure the RDU operates as designed.
warpig
Louisiana
Thanks I am going to bring it in and let the shop do it. I want to make sure there is no damage and if there is then they fix it. I do not know much about RDU's but when I her grinding like that something has to be messed up. I have rebuilt engines, front ends and mechanic work but just no experience with 4wd and RDU. I think I am going to have them change the transmission fluid also.
V8 Yankee
Harold
Miami
21 Bronco Sport
Make sure you ride along with the technician. Even better to drive it yourself with the tech next to you to duplicate the grinding and shudder. In my case I had a obvious shudder when backing in reverse while turning full right, full left also but not as much. If the tech takes it by themselves then he may come back and say he didn't hear or feel anything. That happened to me. The second time, different dealer I drove. It took 3 minutes for the tech to confirm the shudder. Thankfully under warranty at the time.
FatmanOSU
Oklahoma
2022 Bronco Sport Big Bend, 2001 F150
How much did it cost to fix your RDU? Mine is making the same noise. Only 25K miles on it.
warpig
Louisiana
I did not have it done yet. I purchased the Ford extended warranty so it should be free. I need to make another appointment. Bayou Ford sucks long story. Truly every Ford service center sucks in my area. I also own a 2024 F150 Lariat and have always been a Ford person. That is my last ford purchase. They make crap now. Look at the problems water pumps, RDU, Battery and other things. The F150 has its own issues. Been looking to trade the BS in on a Mazda.
