Rattle noise on acceleration and deceleration video
FordGuy
FordGuy
Jordan
Did you start a case with Ford? It's the best thing I could have done. The dealer and crew kept my Bronco Sport for several days and finally heard the rattle/grind (and no, it was NOT normal engine sound). They determined it was a defective transmission so they ordered a new one and it's getting replaced this week. I'm hoping that's the problem. We'll see.
UPDATE - dealer was useless after having it for a couple days.
I actually removed the park release cable today and then drove it. Wow. So much quieter at least so far 🙂. At least that’s confirmed to have caused or acted as a pathway for noise from the engine bay the rattles are non existent between gear changes
Did you completely remove cable or just pull the connection off the transmission?
FordGuy
FordGuy
Jordan
Completely removed because with it still attached to the transmission with the one bolt, it’s still under some tension on the wire so I thought lcd remove completely and see how it sounds
Bdud
Brian
Chicago
Thanks for keeping us updated. It looks like this may actually fix your issue.
FordGuy
FordGuy
Jordan
Yes. Still good. No noise. I have the revised cable ford invented in December but just wanted to see what would happen if I took the original completely out and it’s nice
Dave
Tammy
Mason, WI
Finally got myself a decent video (turn up volume) of the wierd rattle from the front driver side on acceleration. Listen carefully and you will hear it.
Anyone else have this occurring ?
Between 0 to 35 mph (50 km/hr) light on the throttle and you can hear the weird rattle sounds in the video. Seems to occur more around gear changes I think.
Update. I did not need a new transmission. It was the park brake cable which is attached to the transmission.The way it was was positioned caused reverberation that made all the noise. They ordered a new updated cable from engineering and replaced it and all the noises are gone. The field service engineer from Ford came to my dealership and they worked together to solve the problem.
FordGuy
FordGuy
Jordan
Hey. That’s great news ! Mind you I still get a chatter when I hold speed around 43 km/hr but the constant annoying clicking rattle is gone
Broncette
Tracey
So my new 22 Badlands has this noise. It's loud. Happens when braking/accelerating at low speeds. I have <200 miles on it.
Hello, Tracey! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this noise concern. Thanks!
Fredghost
Fred
Irvine
When I took my bronco into the dealer they told me it was normal and it’s just how they are.
I’m really hoping ford pushes a recall out for 2022s like they did for 2021s
Broncette
Tracey
I don't know if you have the same noise as me but my dealer is getting me a loaner so they can spend more time trying to figure out what's causing the noise. But he said it is perfectly safe to drive.
CactusJack
Brandon
was there a recall for this issue on the 21s? mine makes the rattling/chattering noise under low engine load/low speed/low rpm (more specifically - driving slowly through a parking lot between 15-20mph, very light on throttle and at/under 1700rpm)
I have an oil change appointment on 10/10, I'll mention it to them then
Hey there! I can look into your Bronco’s noise concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
bjbena
Barry
Escape SEL. EcoSport SES
Hey! Your keyboard is working again ...
