Rain guards adhesion
chipearly
Chip
Wytheville, Va
2022 Bronco Sport Big Bend
Those that have the rain guards on the windows from Ford, might want to check them from this cold weather. Driver side was loose so i decided to pull it off. Then pulled the others. All of them barely had adhesion just popped off.
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
I have the EGR window deflectors (front in-channel, snap in, rear use 3M VHB), and the rear did pull loose after less than a year, in spite of cleaning and de-greasing the weatherstripping in the top of the window channel.
That did not happen on my '17 Escape which used the WeatherTech window deflectors (pretty much identical to the EGRs). I had that car for 7 years.
But, I think it could happen to any of the window deflectors which are taped in.
Good to be aware!
Sojourner
Maryland
I have the AVS version and had to replace the tape on 3 of the 4 visors after only 15 months. That they stick to rubber in some places is the main problem, I think. Will probably try an in-channel version down the road (if they're available).
