Info in this post has not been validated to be correct. Others who positively know for sure can chime in and correct …
Some of the following features may or may not be available on your Bronco Sport so are listed as “if equipped”.
Location and information:
Shark Fin Antenna: AM/FM/HD, Located on the roof of the vehicle is the cylindrical screw-off antenna portion
SiriusXM Antenna if equipped: integrated into the Shark Fin Antenna (housing)
GPS: separate antenna unaffected by the Shark Fin Antenna
FordPass Modem (Telematics): separate antenna unaffected by the Shark Fin Antenna
AT&T Hotspot Modem Antenna if equipped: separate antenna unaffected by the Shark Fin Antenna
Details:
Radio Antenna Base (aka Shark Fin Antenna)
STANCHION. Base. Radio Antenna Base
W/Sirius XM Satellite Radio (if equipped)
Fits Bronco Sport (2021 - 2023)
Part Number: MCPZ18936C
Supersession(s): MCPZ-18936-C
Info on various stubby antenna for the Shark Fin: https://www.broncosportforum.com/forum/threads/shorter-antenna.2039/
GPS Antenna location: behind the dash at the 8” Display
Gps Navigation Control Module. Central Processing Unit.
FordPass Modem (Telematics) Antenna location: behind the dash at the 8” Display
Telematics Control Unit module
AT&T Hotspot Modem Antenna location: behind the dash at the 8” Display
Background info:
https://www.broncosportforum.com/forum/threads/where-is-modem-located.3153/
signal strength map based on your location:
https://radio-locator.com/
Notes:
Ford deleted the AT&T Hotspot (AT&T 4G LTE WiFi Hotspot) Modem in 2022 for certain vehicles including Bronco Sport. There was no impact to FordPass Connect because FordPass Connect uses a separate modem.
The terms WiFi and Hotspot are often confused because both WiFi and a Hotspot help a user access the internet. WiFi is a technology that allows for wireless communication, while Hotspot is a hardware device that provides a point of internet data access.
The AT&T Hotspot (AT&T 4G LTE WiFi Hotspot) modem device provides an access point to the internet and provides WiFi inside the vehicle using AT&Ts 4G LTE data service to access the internet.
Details:
Background info:
Notes:
