LED bulbs for tail lights
Rdav01
Rick
Indiana, USA
2021 Bronco Sport Badlands
3157 - Red - Brake Light
7443 - White - Reverse
921 - Amber - Turn
Do you need to use Red? could you use white LEDs since the brake light is red already?
Rdav01
Rick
Indiana, USA
Also Rough country has some decent bumper and rack-mount light bars
SLJ
Elbridge NY, USA
Bronco Sport OB
Be aware that that Rough country front bumper light bar will block any front camera or 360 sensor if you have them.
Rdav01
Rick
Indiana, USA
Really? on the Badlands the front cam is up by the O and N lettering and the vid looks like it doesn't stick out much from inside that opening but I don't know 100% ( Badlands is the one I'm getting )
SLJ
Elbridge NY, USA
Bronco Sport OB
I guess it's the front sensor it blocks as the camera is higher.
Rustlesee
Russell
Spokane, WA
Must match the color to the color lens. If you don’t, the LED color will come out wonky. Not worth the gamble.
Martinjv71
Martin
Chicago, IL
2024 BadLands
Thanks. That will be a big help for the LED Taillights posts.
sdchrisp
Chris
San Diego
Thanks to @MKohlman the LED lights for the Bronco Sport are:
921 - Amber - Turn
I have used the Philips Ultinon bulbs off Amazon for my Brake and Reverse lights, and per MKohlman's advice the Lasfit 921 LED bulbs for the Turn Signal. I will say now the Philips aren't brighter - but I wasn't looking for comically bright replacements. However once getting the Lasfits in - I might need to replace the Philips bulbs to match!
Hopefully we can run a list of bulbs that fit the housing and also seem to work well for the vehicle. So far my only "downside" is the 921 bulbs seem to blink at the rate they should - but the dash flashes 2x faster in a "hyperflash" manner - even though the bulbs themselves don't. I am assuming this would be a ForScan item - once we can get that going.
Would you be able to post the links for all three different LED bulbs you ended up buying? For some reason I can’t find them.
NavyBOFH
Alex
SE USA
21 Bronco Sport
Sorry for the late reply. I have been swapping bulbs out finding the best combination. Right now I am on Putco bulbs that you can get off Amazon and are almost identical to the Sylvania ZEVO in design (the first model with round heat sinks).
My issue is that I’m getting the occasional hyper flash from my right turn signal. It’s almost like the BCM is trying to learn the loading value of the LED bulbs but can’t. Since no one else is talking about it I don’t know if it’s specific to my vehicle or I’m having bad luck with bulbs.
Danible
Indiana
2021Orange Bronco Sport Badlands/ 2020 F150 Apex
Can you use get rid of hyperflash with forescan?
Rdav01
Rick
Indiana, USA
These are the ones I got off Amazon are very bright and I have had no Hyper flash on the turn signals.
3157 - https://www.amazon.com/gp/product/B07WZ5XWDY/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
921 - https://www.amazon.com/gp/product/B081YJ9FL6/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
7443 - https://www.amazon.com/gp/product/B07WXTVHD3/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
sdchrisp
Chris
San Diego
sdchrisp
Chris
San Diego
I tried one at night but it seems to blur so did a daytime one instead but night definitely shows the better brightness.
Amazing! You rock!! Thank you so much!
