Knobs + Buttons
The four buttons really control your off road components. Then a few more component there isn't a button for like throttle response. Think of the GOAT dial like a compilation of presets for different terrains. You can select a preset and then make adjustments.
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
Rgill
Vegas
Las Vegas
Would you like a moonroof ? Have not opened mine up as of yet . But I do ride with the sun shade open . Did not have a choice for 21 . Looks like you are close to getting yours .
Yup! Crossing fingers no more delays! No moonroof for me :)
Reactions: Jrl
Deleted member 6350
Nah don’t worry about it, use it that’s what it’s there for. Especially now that it is under warranty.
Reactions: Jrl
Hobbit
Bibby
Bc
Ford sport bronco
Put your car in park , then try each goat mode after you select a goat mode look at those 4 icons surrounding the knob when they light up it then will be engaged. There is a good explanation in the manual on this , take some time and read . My 2cents
I was wondering what the car in like water looking button is?
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
I believe you are referencing the trail control mode? You are to set a low speed and the BS will maintain it for you.
manet444
manuel
bologna
bronco sport 2022
Someone know what happen if put the badlands goat switch (w 4 buttons) in a outrrbanks? Connectors pin are The same…so ehat happen about bottons and functions!? OB Have no some hardware but for example the traction off may works?!
Ford Bronco Sport Knobs + Buttons IMG_2596
Ford Bronco Sport Knobs + Buttons IMG_2597
