Can someone explain the four buttons around the GOAT knob? Are they used independently or in conjunction with the GOAT modes? I've Googled, YouTubed, etc ...
Put your car in park , then try each goat mode after you select a goat mode look at those 4 icons surrounding the knob when they light up it then will be engaged. There is a good explanation in the manual on this , take some time and read . My 2centsCan someone explain the four buttons around the GOAT knob? Are they used independently or in conjunction with the GOAT modes? I've Googled, YouTubed, etc ...
Thank you. I could only find information on the GOAT modes in the manual, not the buttons. I'll check again.Put your car in park , then try each goat mode after you select a goat mode look at those 4 icons surrounding the knob when they light up it then will be engaged. There is a good explanation in the manual on this , take some time and read . My 2cents
Like if you put your goat mode in mud and ruts it will turn on automatically 4 wheel drive . You can monkey around with each mode you canāt hurt it . I think so far I have used sport mode only .just to see how it works , I donāt think you can hurt anything . Learn while it is under warranty. Have a blast .Thank you. I could only find information on the GOAT modes in the manual, not the buttons. I'll check again.
Excellent suggestion JRL. Watching what they do to the locks, 4x4 etc can best be understood by watching it as you switch from one to the otherLike if you put your goat mode in mud and ruts it will turn on automatically 4 wheel drive . You can monkey around with each mode you canāt hurt it . I think so far I have used sport mode only .just to see how it works , I donāt think you can hurt anything . Learn while it is under warranty. Have a blast .
Have you got your badlands yet . Have a blast with sports mode . I donāt use it all the time but it will definitely make you smile ?. Thanks I have been here for awhile just trying to help out . Very sharp alto blue was wanting it in my first edition but was not one of the first edition .Excellent suggestion JRL. Watching what they do to the locks, 4x4 etc can best be understood by watching it as you switch from one to the other
Here is one of the best write ups I have seen that does what you ask. The staff member and administrator at Bronco NAtion posted it. Near the bottom it discusses how the buttons interact with the GOAT mode selections.Can someone explain the four buttons around the GOAT knob? Are they used independently or in conjunction with the GOAT modes? I've Googled, YouTubed, etc ...
Yes I think that is called trail control maybe, it is low speed cruise . I actually tried mine , very interesting. Sorry about that my mistake . I got carried away on a different point .Without getting off the sofa and checking, I think on my BS BL one button when on allows you to take your foot off the brake after coming to a full stop and the brake will hold until you accelerate.
Do the buttons just light up to reflect the mode? Nothing is activated when they are pushed? I'm in the UP of Michigan for the holiday weekend and have used the Slippery mode quite a bit by turning the knob.Excellent suggestion JRL. Watching what they do to the locks, 4x4 etc can best be understood by watching it as you switch from one to the other
Yes they do . For winter drive definitely slippery modeDo the buttons just light up to reflect the mode? Nothing is activated when they are pushed? I'm in the UP of Michigan for the holiday weekend and have used the Slippery mode quite a bit by turning the knob.
Auto hold/ Good feature below the park buttonWithout getting off the sofa and checking, I think on my BS BL one button when on allows you to take your foot off the brake after coming to a full stop and the brake will hold until you accelerate.
For sure , mine has been on since I got mine back in March, I would say it is my favorite extra .Auto hold/ Good feature below the park button
Would you like a moonroof ? Have not opened mine up as of yet . But I do ride with the sun shade open . Did not have a choice for 21 . Looks like you are close to getting yours .Auto hold/ Good feature below the park button
Badlands and First Edition Exclusive Modes
- Mud/Ruts - Ford says Mud/Ruts engages 4x4 lock so that you can keep going even if you have a tire that canāt get traction. It does not engage the Rear Differential Lock. However, 4x4 lock can be selected independently of the GOAT modes. This seems to mean that when you select Mud/Ruts thereās something more that the system does than just engage the 4x4 Lock but we donāt have details on what those additional optimizations are.
- Rock Crawl - Rock Crawl mode engages both 4x4 Lock and Rear Differential Lock and adjusts throttle and transmission response. Our guess is that those adjustments are centered around keeping as much torque as possible in the low range so you can get more power into a slower wheel turn that is less likely to lose traction. Again, both 4x4 Lock and Rear Differential Lock are selectable outside of the GOAT mode dial so if you donāt like the decisions that the system is making, it looks like you can select those and exert more control over what the vehicle is doing. Similar modes in other Ford trucks, like the F150 Tremor, change transmission, traction control, and other systems to improve the vehicleās low-speed crawling capability.
