How big of a tire with minimal rubbing on a 1.5" lift?
jwagner3
john
macon ga
ford bronco sport
Hey guys, I am thinking about buying the 1.5 inch lift kit from rough country and right now I know that the biggest tires you can have is 245. If you add that 1.5 inches how big of a tire do you think I could fit with minimal rubbing?
Zander1ni
Alexander
Encinitas, CA
Golf tdi
a 245 will rub without a lift. It’s not possible for it to fit properly without a lift.
also don't get the rough country lift. It will break. My sway bar end link brackets snapped on one side and severely bent on the other side, not to mention the blot quality is crap and it makes your vehicle ride like shit. It’s only worth it if you need the extra clearance.
jwagner3
jwagner3
john
macon ga
ford bronco sport
So pretty much wait for another lift bc the rough country ones shitty is what ur saying
broncobuster2550
Dearborn
Something slow
No lift will help with tire clearance because the limiting factor is the body pinch wild flange rearward of the front tires. Sounds like more than a few people have been able to up the section size to 245 without issues, but I'd be really hesitant to go beyond that.
Zander1ni
Alexander
Encinitas, CA
Golf tdi
Yes 100% if you read feedback from here it’s nothing but problems. I had to go back to the factory Ford sway bar end links.
4wheelparts has a 1 inch lift level and Robby Woolworth has a 2 inch lift. I haven’t used them but I would definitely recommend them over the rough country lift kit
BigD
Donnie
Alabama
I have 245s without a lift. I also just ordered the Ford Ranger lift.com 2” lift
Ford Bronco Sport How big of a tire with minimal rubbing on a 1.5" lift? 6E2792CB-9702-44F9-9586-92CDF212E9EF
Jcap69
Gallatin, TN
2021 Bronco Sport Big Bend - Shadow Black
Hey Guys,
To the two guys that have the 245/65r17 tires on their Broncos with no rubbing. What model Broncos do you have. I know the Outer Banks comes stock with an extra 1" lift already from the factory. I have a Big Bend and was hoping to go with either the Falken Wildpeaks 245/65r17 or BFG K02s. Let me know what you think. Thanks,
