Fuel additives 1.5 engine
OLDCROW53
Frank
Sumter SC
What fuel additives does Ford recommend for the 1.5 engine i
TheX
Randy
Austin TX
www.netwerkin.com
I asked YOUR question in the good ol' googles and it said this.
Ford generally recommends against using aftermarket fuel additives for the 1.5L EcoBoost engine, stating that modern fuel already contains sufficient detergents. Using high-quality fuel, such as Top Tier gas, is suggested to maintain performance.
Key details regarding fuel for the 1.5L engine include:
  • No Additives Needed: Ford does not recommend extra additives or treatments for normal use.
  • Approved Cleaners: Some reports indicate that Ford has approved specific BG products for maintenance, specifically BG 44K Fuel System Cleaner (every oil change) and Air Intake & Valve Cleaner (every other oil change).
  • Fuel Requirements: The engine is optimized for 95 octane (or similar) unleaded fuel.
  • Fuel Quality: Using gasoline with more than 10% ethanol is not recommended, as it may cause engine damage or affect the warranty.
Potential Risks:
  • Oil Additives: Ford explicitly warns against using oil additives or engine treatments, as they are unnecessary and may cause damage not covered by warranty.
  • Carbon Buildup: Because this is a Gasoline Direct Injection (GDI) engine, fuel additives do not clean the intake valves directly. The previously mentioned BG air intake cleaner is for this purpose.
Big Ben
Rick
Calgary
The 1.5 in the BS has port and direct injection , so fuel wash does clean the intake valves.
Frenchy906
2025 Bronco Sport Badlands
The 2025 has port and direct.
Prior years are direct injection. That was their main change to the engines in 2025.
Stircrazy
BC, Canada
2023 Bronco sport
wrong, my 23 has direct and port injection also. I am still not sure why they list that as a engine change when all the previous ones had it also, unless maybe they are talking about the 2L spicificly with that as the 2.0 never had it prior to 2025, while the 1.5L did.
Big Ben
Rick
Calgary
I believe that's wrong My 23 specs say port and direct The Ford Escape forum says that the 21 Escape has dual injection with the same engine.
jj1
[/QUOTE
Is the 25 2.0 direct and port? I’m confused,
OBSASQ
Nebraska
2025 Bronco Sport/2023 Maverick
From the 2025 BS manual:
Your vehicle operates on regular unleaded gasoline with a minimum pump (R+M)/2 octane rating of 87.Some fuel stations, particularly those in high altitude areas, offer fuels posted as regular unleaded gasoline with an octane rating below 87. The use of these fuels could result in engine damage that will not be covered by the vehicle Warranty.
Do not use:
• Diesel fuel.
• Fuels containing kerosene or paraffin.
• Fuel containing more than 15% ethanol(E15) or E85 fuel.
Fuels containing metallic-basedadditives, including manganese-based compounds.
• Fuels containing the octane booster additive, methylcyclopentadienyl manganese tricarbonyl (MMT).
The use of fuels with metallic compounds such as methylcyclopentadienyl manganese tricarbonyl, which is a manganese-based fuel additive, will impair engine performance and affect the emission control system.
mikldom
Outer Banks NC
AI is not always the best source.
The fuel fill-up nozzle clearly says you can use up to 15% ethanol.
I have used it many times where available. I am up to 110k on my 22 BS OBX and no Ill effects.
Always used 87. Now that I am over 100k and I dont drive near as much I am getting 89 octane most of the time.
Still runs perfect and still the original water pump.
Oil changes with full synthetic every 4k and always put in LiquiMoly MoS2.
Unicorn
Chester
W. WA
BS Badlands with Sasquatch.
They don't recommend any. But if you don't use "Top Tier," gas, you should consider adding a small amount, a few ounces, of something like Techron at each fill up. Not a full bottle of the Techron Complete as that puts too much PEA into the fuel. Something like ten times the concentration that would be in their gas, and they say no more than two bottles between oil changes. It can cause oil dilution. Regane also has an additive with PEA that works to keep it clean. Same thing though, just use about 2 ounces per tank as a maintenance dose.
