Fast Left Blinker
nhchemist
Richard
NH
Expedition, S2000, Bronco Sport Badlands
When I turn on the left blinker, it hyper flashes like a bulb is out. The right blinker is fine. When I compare left and right blinkers from the front, they appear to be the same. Same for the rear. I decided to look at the individual bulbs, but the plug has multiple conductors where it plugs into the headlight/turn signal module. I found three screws to remove to pull the module, but it did not budge. Where do I go from here?
Victorsen
Victor
Maryland
You have to go to the dealer I had the same issue one of the led lights on the brake may be out. You can’t tell it is all connected and when fast blinking there is a fault somewhere
nhchemist
nhchemist
Richard
NH
Thanks for the reply. I'll give them a call.
Typically a bad brake light bulb is the cause of the fast blinking signal light issue. In your case check your left rear brake light and replace as needed.
MarkyMark75
2021 Bronco Sport BB
Just had the same issue. Mine was a brake light. 3157 bulb and 2 minutes later it was fixed.
Ford Bronco Sport Fast Left Blinker 1684605648203
Ford Bronco Sport Fast Left Blinker 1684605663194
P27 bulb equivalent is a 3157, the 27w 12.8v Automotive Miniature light bulb
Be careful when pulling off and reinstalling that black trim piece adjacent to the tailight housing, it has tabs that can easily be broken.
nhchemist
nhchemist
Richard
NH
Problem solved. The blinker bulbs were good. It was the stop bulb that quit working. New bulb installed and all is good.
