2024 BS OB wiring behind dash from driver side to passenger side
Troiano27
Jeff
Nashville
2024 Bronco Sport
Looking for advice. 2024 BS OB. Will be installing an auxbeam AS-R60 6 switch pannel soon. Planning my install. Going to go through the firewall via the rubber grommet behind the battery. I’m trying figure the best way to run the wire behind the dash, and get it out on the passenger side the the center consul. The fuse panel is located below the glove box and I need ACC power. Also, I want to run the switch panel wire around that side, or if possible into the lower cubby where the 12v outlet is located. Anyone do this, or have any advice. Have watch videos on removing the infotainment screen and AC panel, that could be a possibility for access?
wireman
Murrieta
Just be careful if it's a metal fish tape. May want to disconnect the battery.
Or use a fiberglass tape. Don't want to poke into energized areas. Better to be safe.
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
yeah fiberglass always safer. its pretty simple to find though.
I also ran charging cables for my tackform mounts through the mounting hole in the trim piece behind the center display and down behind the dash that way to underneath the dash. I did remove the screen to get better access to run those wires.
TonyACK
Tony
Check this YouTube Video
