- Thread starter
- #1
Looking for advice. 2024 BS OB. Will be installing an auxbeam AS-R60 6 switch pannel soon. Planning my install. Going to go through the firewall via the rubber grommet behind the battery. I’m trying figure the best way to run the wire behind the dash, and get it out on the passenger side the the center consul. The fuse panel is located below the glove box and I need ACC power. Also, I want to run the switch panel wire around that side, or if possible into the lower cubby where the 12v outlet is located. Anyone do this, or have any advice. Have watch videos on removing the infotainment screen and AC panel, that could be a possibility for access?
