DZG LED Side Marker Lights
BoxerBronco
Aaron
21 Ford Edge ST Line, 22 BS Badlands
Just reviving this thread…looks like these are available on Amazon.
Anyone?
Pmk1710
Peter
I got them installed on mine. Look great, work great, easy install. I did splice them directly into the signal light wiring from the headlights. Ive had no light dimming issues or electrical issues post install.
The wires are a very thin gauge, and I recommend taking some hot glue to the back of the inserts just to secure them a bit more, and create some additional seal form the elements. but, the wires were long enough to get to each headlight assembly for splicing.
BoxerBronco
Aaron
@Pmk1710 thanks for this info…great to know that they don’t cause any issues…good tip on the wiring. I would be soldering, shrink wrapping and shrink wrapping again!
Dustymedic
Bob
Central Ohio
2021 Rapid Red Bronco Sport OB
Just got mine from Amazon today. Waiting for the heat to break to install them..
Kraken1
Larry
Ontario
I want to hook mine up to the side marker light but I can't figure out how to pop out the side marker light. Can anyone help me with this, please?
jimharrison1950
Buckeye, AZ
2022 Bronco Sport Big Bend HOT PEPPER RED
Anyway, you could send pic of where you tied into the turn signals. Thanks
PonyDriver43
Roger
NE FLA
You can turn front wheels and remove 3-4 of those plastic push pins and pull inner fender liner out of the way and reach it that way. It is very tight but can be done. That is where I powered my "raptor" lights.
Kraken1
Larry
Ontario
Thank you for responding. Yes, I got that far but I wanted to pop out the marker light and finally had to give up.
MyKindOfBS
Atlanta, GA
I was thinking about these. The reviews for the TECTICO are not that great. Any better luck from these?
