shakeandbaker
Austin
Cactus Gray BS Badlands, BMW 135i
Just took delivery of my Cactus Grey Badlands over the weekend. Have never been off-roading prior to purchasing this vehicle, so naturally I headed straight for the trails!
I don't have much to compare this to in terms of off-road capability, but all I can say is that this thing handled mud and deep ruts, steep climbs, fairly deep water easily. Felt like it really could go over anything, and throttle/brake control was so easy on all surfaces.
What have your impressions been like taking your Bronco off-road?
Zander1ni
Alexander
Encinitas, CA
Golf tdi
I have a big bend model and have been similarly impressed!
where is that trail? It looks like the same one I did near the Palomar divide truck trail
shakeandbaker
shakeandbaker
Austin
About 40 min outside of Austin, TX. Moved here recently from San Diego and would love to take this thing out around there one day.
BamaBronco
TJ
Alabama
DISCLAIMER: This is a lengthy write-up, so grab your favorite beverage and kick back as you read. Also, I wasn't sure which thread to post this so I figured this thread was as good as any considering it was my first time taking my BS off-road.
I did some research and found some trails in my general area. I found a few that are within 1-2 hours away on trailsoffroad.com. I work in sales and coincidentally, one of my customers is about 15 minutes away from a trail I wanted to try. I had an appointment with them this morning so since I was in the area, I decided to try this trail on my way back home. See the link below to the trail I went on. Watch the embedded YouTube video further down the page for a good idea of the type of trail/how difficult it is.
https://www.trailsoffroad.com/trails/2331-talladega-national-forest-617
I entered the trail on the north side and quickly noticed there was a lot of mud since it had recently rained. I remembered reading that the trail grew considerably more difficult after rainfall.
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_164416689_iOS
The first few hundred yards or so were not too bad. I went through some rutted-out mud holes that at first glance looked more challenging than they ended up being. The BS acquitted itself nicely with no problems.
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_170317501_iOS
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_165958523_iOS
I eventually got to a portion of the trail about halfway through that was the first challenging spot. The first section was a rutted out area that led to a narrowing of the path in between embankments with not a lot of room on either side.
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_165400769_iOS
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_170009983_iOS
I put it in Slippery mode and Low gear and made it through all of that no problem, but as I was going up the narrow portion of the trail, I could see a bugaboo upcoming. I circled it in red below. You can't tell from the picture, but the rut was about 4-5 feet across and looked like it could be 2 feet deep or more on the left side. I was by myself so I figured I wouldn't risk it. With a spotter and recovery equipment I may have given it a try.
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_170009983_iOS (2)_LI
A little disappointed that I wasn't able to finish the trail, I started back the way I came. I came back to an obstacle that I had sort-of bypassed and decided to give it a go. Again in the picture, you can't really tell but I tried going straight through with two deep, rutted-out lanes and a high center. As I went up and started going down through the rut, I drug the front underbody and said NOPE. I backed out and went around. The picture I took is when I came up to it the first time, so I should have taken another picture to get a better angle of what I was actually going through.
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_165200048_iOS
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_165200048_iOS (2)_LI
Overall, I was impressed with the off-road capability of a non-BL trim. I can tell that traction is not an issue and the 4WD system is quite capable. The suspension soaks up bumps and ruts as it should. I recently replaced the stock tires with new 245/65R17 Toyo Open Country ATIII tires and they performed well. I never lost traction or control even in deeper mud. The only issue, as you can surmise, is ground clearance. With the larger tires I have a little over 8", but I would say the BS needs about two more inches. The good thing (that I did not previously know about) is that there is SOME underbody protection. Some may scoff at this, but it does have plastic skid "plates", which is better than nothing! When I scraped the bottom going through the muddy rut, I did not sustain any damage.
Next, I would like to find a trail that is mostly loose rock or gravel and see how it does going up steeper inclines. I'm done with mud for a while because it got absolutely filthy. I hosed her off once I got home and you wouldn't believe the cracks and crevices mud can find it's way to get stuck in.
Let me know if you have any questions and thanks for reading. Cheers!
Ford Bronco Sport Bronco Sport Off-Road Driving Impressions 20210125_170858171_iOS
BagOJuice
Long Island
Good stuff. Thanks for posting. Cant wait to take mine out on some trails, been trying to find some stuff like this to read! Now comes the hard part... finding some trails by me...
MattH88
Matt
Seattle
This is awesome. If you made this its own thread, you'd make a lot of BB owners considering 245/16R17 tires very happy. Thanks for the review. Looks like no rubbing issues with the 245s, which locks me into my decision to get 245s. Thanks!!
BamaBronco
TJ
Alabama
No problem! And yeah, I thought about doing that initially but I did comment on a couple of related threads about this post to get the word out. Hopefully some people will find it beneficial.
Tom House
Fairfax, CA
Subaru Outback
Off topic but have you read the essay going around about the family that moved from SD to Austin?
shakeandbaker
shakeandbaker
Austin
I haven't seen that one. Feel free to PM to me.
ETXBronco
Stuart
Is that the Overland Route near Kingsland? I'm thinking of taking my Big Bend there.
JackBouman
Jack
Bronco
are those the 235 upgraded tires? or the 225's they come with?
ETXBronco
Stuart
This was just a little trail in Bastrop. Haven’t been out to Kingsland. Will have to check that out!
I'll let you know how it goes. My Big Bend is still stock but it's supposed to be easier than taking it to Barnwell Mountain trails in east texas. Still trying to figure out everything I need to upgrade.
