Black plastic bumpers and trim
missOutsyder
KT
Kamloops BC
Does anyone use a particular product to clean and bring the black plastic bumpers/trim up to looking new?
I've not found one that has a long lasting result. Many out there are good to restore black plastics to look good, but they require continued application.
I live in Florida where the summers and UV are brutal on black plastics. On the 2007 F-150 I drive, I ended up painting quite a bit of the black plastic trim pieces with a UV protected black spray paint, available at auto stores, and home depot. It lasts a lot longer than the once or twice applications of plastic restorers I had to do each month.
In order to get the black spray paint to adhere to the plastics, I had to use a cleaner and prep spray to remove the silicones from the restorer products that were used.
missOutsyder
missOutsyder
KT
Kamloops BC
Thanks very much, I'll pick some up this weekend ??
missOutsyder
missOutsyder
KT
Kamloops BC
Scott_Anderson_
Scott
Arkansas
2021 Badlands Cactus Gray
This is good to know. I have a couple of the CG products and just ordered their high foaming soap from Amazon. Will seek this out! Thanks for the info : )
You are welcome. I love their stuff. Good luck and keep us updated.
missOutsyder
missOutsyder
KT
Kamloops BC
davidb1841
Bruce
NC
You can't go wrong with Mothers or Maguiers products.........
But some products like : Turtle wax ICE can be used as a "WAX" and can be used on plastic...even black plastic!,,,,,,(no white residue)...cause its silicone based.......one of my favorite products
