Belly pan
Mrmike
Mrmike
Syracuse, New York 13219
Syracuse, NY
Ford Bronco Sport Belly pan 1667177338741
might not go rock climbing
but they might come looking for you
wheel well ice build up
upstate NY potholes let frozen ice boogers loose to oncoming traffic
large tractor trailer sized boulders of solid ice
okay that was a bit of a stretch but we could agree these are trouble, no?
same scenario here
not going rock climbing
but lower components are far game to these frozen winter wonderland gems
may bite the bullet and slap one on even though an oil change obstacle
No problem for me. My vehicle goes in a heated garage every night. I'm retired, and if the weather is too bad, it may stay inside foe several weeks.
I did see another pan being sold that had a hole to access the oil drain plug, and a removable door to get your arm/hand up to remove the oil filter (JCR). One complaint on a thread though was that the hole to remove the oil drain plug allowed a ratchet/extension/socket across, but the oil draining made a bit of a mess coming down through the hole, as it was not large enough or offset.
Here is a vid that describes it (scroll down). At 8:10 into the vid, it describes the access cover to gain access to the oil filter and drain plug cutout.
https://www.jcroffroad.com/product/BSSD-GN-1G.html
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
roger that
Sparkplug just came out after a long winters nap
check my fitbit statistics
I put more mileage on my sneakers than the Bronco Sport
sneakers: 945 miles/2022 year
Bronco Sport: 742 miles/2022 year
:D
roger that
:D
Better for the environment, worse for plantar fasciitis.
Blue oval fan
Nick
Greenville, SC
22 Bronco Sport
I have the Rival and have to remove the entire thing. JRC you do not, it has the ports for bot filter and drain. I would have gone with the JRC, but Rival was the only option at the time. The rival is pretty heavy and kinda a pain but only takes me a couple of minutes to remove it, I have done 3 oil changes already so I'm getting the hang of the routine.
cprcubed
Patrick
Parker, TX
Major Kong
Major
latin for a fascist gardener.....whut?
okay doc ya got me
I had to look it up
"The cause of plantar fasciitis is poorly understood. It is more common in runners and in people who are overweight"
dodged both those bullets
but I need a new pair of sneaks already
