2025 MY Bronco Sport Goodyear Tires and new wheels discussion
Recent articles have stated MY 2025 will sport a brand new wheel design and Goodyear Territory RT All Terrain 235 65 R17 tires.
‘21-‘24 Badlands came standard with 225/65R17 tires from various manufacturers and optionally with Falken Wildpeak AT3w tires:
Tire comparison: OEM Pirelli 225/65R17 vs OEM FALKEN 235/65R17 (Note: most data from https://tiresize.com/calculator/ so may not be actual reality):
(EDITED) Weight 25.22 lbs vs 31 lbs (+5.8 lbs per tire)
Diameter 28.5” vs 29” (+1.8%)
Width 8.9” vs 9.3” (+4.5%)
Sidewall 5.8” vs 6” (3.4%)
Circum. 89.5” vs 91.1” (+1.8%)
Revs/Mile 708 vs 695 (-13)
2025 MY Bronco Sport shows with a brand new wheel design which may have different wheel weight and wheel offset compared with standard and available wheels on the ‘21-‘24 Badlands.
EDITED: updated info including tire weight and part number is at this link:
https://www.broncosportforum.com/forum/threads/2025-my-bronco-sport-goodyear-tires.14109/post-230964
RWT
S.E. Georgia
"RT" in an off road tire usually refers to "Rugged Terrain". Rugged Terrain tires normally Fall between an AT and a MT in regard to tread design.
JMHO
No expertise implied or expressed.
Weight 28 lbs vs 31 lbs (+3 lbs per tire)
The Goodyear Territory RT All Terrain 235 65 R17 tires do not yet seem to be available but let’s assume like the OE Falken tires, there will be an OE Goodyear Territory RT All Terrain 235 65 R17.
There are these 2 existing Goodyear tires but neither come in the 235 65 R17 size:
Wrangler Territory AT
Wrangler Territory AT (Light Truck)
There is the Goodyear Wrangler Workhorse AT in the 235 65 R17 size.
Does anyone have a link or specifics for the Goodyear Territory RT All Terrain 235 65 R17 tires?
I have on my2021 bronco sport First Edition , Goodyear wrangler workhorse 235/70/17 30.01 diameter. Fits perfectly.
Mt Goat
Rick
2025 Badlands Sasquatch
I have searched and found nothing. I think they are a new tire designed specifically for the Bronco Sport Sasquatch. Since those will be coming out pretty soon, I would hope the tires would appear at some of the tire dealers shortly.
I’m hoping they will be similar in weight and tread design as the WildPeaks. The WildPeaks are a great tire and I’m disapointed they are going to be going away.
