How many wires go to the LED Modules you posted about earlier. Am curious if there are 3 wires to each module
pantera155
pantera155
Pantera
Argentina
Bronco BADLANDS 2025
There are 3 wires. Positive, negate and LIN.
Stircrazy
BC, Canada
Will have to go back thru the posts on the center connector ambient lighting and under footwells - my recollection is 2-wire connectors but am probably incorrect
seams ford uses a 3 wire lin setup for interior and accent lighting, which means I should be able to addjust the color of mine as well as the brightness/ unless they used a single color led and are only using it for brightness, or there is still somthing else I need to activate in forscan....
pantera155
pantera155
Pantera
Argentina
Vou trabalhar a proxima semana. :muscle:
pantera155
pantera155
Pantera
Argentina
It finally worked :muscle: :muscle: :muscle: :muscle: :muscle: :muscle: :muscle: :muscle: :muscle:
It was pin 31 for the bus and pin 4 for +12v.
Now I just need to put it together for good, and I think I'm going to buy the cup holder with the lights.
I'll show you how it turned out later!
Thanks to everyone who helped! :rockon::rockon::rockon::rockon:
pantera155
pantera155
Pantera
Argentina
726-14-07:
Changed to: xx3x-xxxx-xx
726-21-01
Changed to: xxxx-x9xx-xx
726-17-01:
Changed to: 2C88-XXXX-XXXX
:handsinair::handsinair::handsinair::handsinair::handsinair::handsinair:
Phantom
Xiangbing
Maryland
Ford bronco sport badlands
Really great work on those jobs!!
I was intended to follow along, but I have a 2024 badlands, which has a different bcm number, and I can't find a wire diagram for my version. In case I burn out the BCM, I decided to go with the aftermarket kits.
Ford Bronco Sport Ambient Lighting install / enabling - WORKED! 1000039509
First, I found a totaled 2021 outer banks at my local junk yard, bought those parts. The a/c control panel with temperature displayed. All trims after 2021 had canceled this option, but I saw from another thread that it's plug-n-play.
The central storage tray with illuminated USB ports. Which is also a feature had removed in mine. The USB port in mine has only a white line around it. It also has the empty light tube at the side that I need.
I also got the cup holder with the light kit.
Ford Bronco Sport Ambient Lighting install / enabling - WORKED! 1000039934
Ford Bronco Sport Ambient Lighting install / enabling - WORKED! 1000039782
That's how it looks like now. If you are interested in it, I'd be glad to write some detail about it later.
pantera155
pantera155
Pantera
Argentina
I used the BCM data from the old version, since it doesn't exist for version 2025.
In version 2025, the pins I used are marked as "unused." And those "unused" pins are what turned on the lights.
