All Dashlights On and Scrolling
Sensei
Sid
Georgia
2021 BB bad battery did the same thing to me.
Irishgirl0413
Irishgirl0413
Jen
St Albans VT
2022 Ford Bronco Big Bend
Would LOVE to know if they found the issue. Mine had been gone since last Tuesday. Hadnt done it once. Picked it up at 1:30 with no lights. Went back to the office and parked it and at 4:30 I started it with the same issue. No power steering, brakes squishy (ABS?) and directionals don’t work. It shut off/stalled in my driveway and wouldn’t turn back on until I locked and unlocked it with my fob. Power steering & directionals work but all lights still going. I have videos of all 4 times now. Getting SO discouraged!
rocks
SC
I'm starting to wonder if some alternators aren't working correctly.
Many have posted suggesting your battery is likely the issue. I suggest you have yours load tested. This is a specific procedure that's more in depth than a simple voltage test. Ask you service dept to do a battery load test.
coopny
NY
2023 BS BL
If the vehicle is still with the service department, ask them to do a load test. Otherwise, pretty much all Advance Auto Parts/O'Reilly/Autozone/NAPA location will load test a battery for free, if that's more convenient for you.
AAA Mobile battery service will come with the battery and a load tester as well (to make sure that it's a bad battery before you replace). If the battery is bad they will replace it for you and recycle the old battery. It does cost a bit more than getting the battery yourself (particularly if not a AAA member), but you don't have to deal with getting to a place to have the load test done, buy the battery [assuming the load test fails], bringing back old battery for recycling, etc.
If your Walmart has an auto center, they have the cheapest AGM I've seen around for the BS ($169.84) and they should be able to load test it as well. If your Walmart doesn't have an auto center, they don't load test.
I wouldn't recommend replacing a battery without a load test indicating it's bad. It seems to be a common cause for electrical gremlins, but it's far from the only thing that could cause such issues.
foreheadsmooch
sydney
tampa, fl
2021 bronco sport
Not sure if this is still active but I am having same issue with my car. I am so tired of having an unreliable car. What did your dealer ultimately recommend ? I’m calling my dealer tomorrow. I have videos. My car has done this before, they said it was a “sensor issue”
