Adding GOAT Modes with FORScan
kshaw
kshaw
Kent
Gaithersburg, MD
is that a code chage or one of the options available? I also have seen that some one has added the cabability to change the color on the accent lighting.
Yes. I did a writeup on the FORScan tread along with some pictures on what it looks like after the change..
Stircrazy
BC, Canada
2023 Bronco sport
Stircrazy
BC, Canada
2023 Bronco sport
ok i'll check that out, do we have a confirmed forscan spread sheet for the bronco sport yet?
ya that is the same as what you can find on the ford page for the most part. I was more interested if I could find somthing that lists all the chages each mode does like that chart above for the bronco sport.
You can switch modes and simply note which components are activated/deactivated (light on/off).
kshaw
kshaw
Kent
Gaithersburg, MD
I posted one that I had developed listing all the options. Since I have not tested all the options, I cannot make a recommendation for them. The documentation that I created was about two versions ago, so there may be changes since then. From what I read, the Bronco Sport is very similar to the Maverick as far as FORSCAN goes, so if you can find a good spreadsheet for the Maverick, that would likely work.
