Accessory Ready - Tray on Dash 2025
Are you just using the OEM mounting bolts or did you use the self taping screws too? I just got mine and I'm not excited about drilling into the dash insert if I don't need too. Hoping it's not wiggly without the additional screws. Thanks :)!
Just using the OEM mounting bolts. Way more than enough for a single cell phone (iPhone 17 Pro Max) with no vibrations
pixlpush
Portland, OR
Thank you sir, I just mounted mine and I agree it's quite solid with just the factory bolts. Nice to have the extra screws if needed for something larger but I'm leaving them off for now too.
I don't love how many fasteners have to be removed to move the ball positions but it's certainly super solid once it's all together. Way more solid than the 1" balls I had directly in the OEM bolt holes with a Ram Mount arm. I think my teeth are more likely to come loose from bouncing around than anything mounted to the RubiGrid :crackup:
Agreed. I set it up where I thought I was going to like it. Then hated it. Had to take it all apart. The extra nuts they give with the ball mounts are way nicer than the lock washer and regular nut too. Just an FYI in case you didn’t use them.
Mine's showing shipped, just got picked up by USPS from Bulletpoint. Better be here by Tuesday, we're headed to Crown King and Prescott on Wednesday!
Could be because I'm a foreigner...first time I've seen a website do that if that's the case!
Not a guaranteed workaround, but VPN to a US server and see if it processes correctly.
