6 Switch Auxbeam Switchbox installed !
M225
CT, USA
2021 Bronco Sport Big Bend
What switch panel box is that?
M225
CT, USA
Auxbeam 6 Switch
Thanks, do you happen to have a picture of the back of the controller? / Where the wire sits / Is it flat? Thinking of mounting options
John J
John J
Cooperstown NY
The back has two small retainer clips on it and two mounting points. I mounted mine flat against the plastic fascia with the bottom on the top of the shock mount cover. I put a rubber pad on the bottom of the switch box to lessen vibration. It's pretty much just a rectangular box. The power connector and all the accessory wires come out of one side so it's easy
John J
John J
Cooperstown NY
The actual controller box in the car is flat and come with either two sided tape or a mounting plate that can be angled. It has one wire coming out the back but is channeled so the controller sits flat.
John J
John J
Cooperstown NY
I might have misunderstood what you were after. Sorry!
CrazyKZ
Ken
Allen, TX
Is Auxbeam better than the RoughCountry one? Any differences?
CrazyKZ
Ken
Allen, TX
To answer my own question, I like the Auxbeam better since it auto-brightens and auto-dims depending on surrounding light.
67L48
Iowa
2019 F-350, 2023 BS BL
For anyone deciding to pierce an existing factory grommet where other factory wiring is present, I highly recommend one of these piercing wiring tools:
Ford Bronco Sport 6 Switch  Auxbeam Switchbox installed ! wire-insertion-tool
The handle is hollow, so it's a continuous "tube" to run a cable/wire through. This allows you to pierce the grommet and run your wire through it nice and clean. Over on other forums, I read two accounts of people accidentally clipping the factory wiring harness when using drill bits to get through the grommets. One of those resulted in a 4-figure repair bill to replace the massive factory wiring bundle the guy accidentally grazed.
Anyway, the tool is about $10 through various outlets and is a worry-free way to punch wires through factory grommets. I used one on a Ford Ranger and wondered why I hadn't ever purchased one of these sooner.
