2025 BS Dashcam Solution
Cactusjk
Jeff
Woodland Hills, CA
I have viewed several threads on this but figured I would start a fresh one in June 2026. Understand that the accessory USB C outlets time out at 45 minutes so I am looking for a good dashcam that can preferably be mounted on something that can attach to The Rubigrid i.e., ball, GoPro mount, etc. and will not overheat before the timeout.
Also, the camera needs to work upside down.
I don’t want to adjust the timeout settings.
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
Not specific to Badlands as long as you have the tech package I think unless all have the outlets behind the screen.
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
Leaning towards the Vantru E1 Pro Mini but have not found any conversion mounts for it.
Iamcanadian
Ontario Canada
Yes all bronco sports have the BYOD tray with USBC ports behind the big screen.
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
Well I solved it myself!
Bulletpoint Rubigrid with ball mount
Bulletpoint dashcam arm and magnetic attachment
Vantru E1 Pro
Short right angle USB cable
Works perfectly and shuts off when I turn the car off when connected in the left USB slot.
No issues with heat.
Ford Bronco Sport 2025 BS Dashcam Solution IMG_0663
Ford Bronco Sport 2025 BS Dashcam Solution IMG_0666
Mine still gets pretty hot, more than I would like.
Maybe more vent holes would help.
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
It does if parked in the sun. I put a UVS100 sun shield up if parked.. I don’t use parking mode. I am still playing with positioning to make putting the sun shield up easier.
I haven't had much time to play with the settings. Might have something to do with the heat.
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
For some reason it now stays on when I turn the car off. Might have something to do with when the battery gets low it shuts off right away. I have put a usb switch in and will see if anything changes.
I noticed sometimes when I shut off the vehicle the screen shuts off but the Dashcam must still be operating because it gets warmer. I just shut it down with the on/off button now. Trying to figure this thing out.
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
i noticed that too but the flashing green light would go off so I thought it was off.
Flashing green - stopped recording.
Steady green - standby mode.
I haven't checked to see how long the USB-C plug is powered up after shutdown. The consensus is around 50 minutes.
I'm going to check the USB-C with something else plugged in, maybe a phone and see how long the charging is active after shutdown.
I use an iPhone shortcut, have a couple of them, one knows when the iPhone is plugged into USB power, the other knows when USB power is removed. Can send a message when USB power is removed.
that way you would know exactly how long the BS timeout was
Remember that the Bronco Sport USB timeout is not a fixed number - it can vary based on the SoC of the BS 12V Battery
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
Is there a trick to using voice commands? They work in the house but have not been able to get them to work in the car?
