2023 emergency neutral procedure ??
BSBB4Les
Les
The interesting thing is if you look up the original part number that I posted in post #30 of this thread (JM5Z7A082C) currently on Ford parts website it now says it does not fit my car. It says it only fits these vehicles:
  • Ford Maverick 2022 - 2025
  • Ford Escape 2024 - 2025
  • Lincoln Nautilus 2024 - 2025
The extra ones that I ordered from the dealer are identical to the PIN originaly provided with my BS. The use of the pin is not mentioned in the owners manual. Per the owners manual we are supposed to jump the battery to put the BS in neutral. The envelope that it came in which is pictured earlier in the thread also says it is for Service Personnel Only and the number on the envelope is not a part number so maybe the dealer just decided not to give you the pin or Ford decided not to provide it to the customer and stopped sending the pins when shipping them from the factory to the dealer. In either case I doubt it is something that I will ever use. I filed my pin with my original purchase paperwork and stuck it in a drawer.
Looks like it. This is a new '24 so I'm gonna assume the dealer either pulled it when they received it or when I bought it. The jump start worked on my '22 with the non agm battery and my '24 has the agm battery. I'm banking on this one not ever requiring the need for that pin!
coopny
NY
2023 BS BL
Seeing the procedure in this thread and that using this part in this envelope if the vehicle cannot be powered on that requires someone to remove the air filter housing (which requires several other tools) is absolutely insane. Am I to expect that my tow truck driver has the other tools (other than the pin) and will help me in removing the air filter housing???
So many vehicles are going to be towed not in neutral and get transmission damage, it's absolutely bonkers. Especially with all the battery/charging systems issues these vehicles have had...
