kenmitch
Ken
SoCal
2025 BS
I already have the Badlands trim, but I thought others may be interested in upgrading their suspension
" Upgrade your Bronco Sport with Badlands Suspension System for increased ride height, improved vehicle stance, and off road capability "
  • Fits: 2021-2025 Bronco Sport
  • Compatible with all Non-Badlands variants
  • 20 mm Front / 30mm Rear Lift over base series
  • Direct bolt-in replacement suspension package
  • Improved Off Road Capability (+1” Suspension Travel)
Ford Performance Badlands Kit
Ford Bronco Sport Ford Performance Badlands suspension kit for Non-Badlands trims Badlands Suspension
Ignoring the one and done hardware, that's a lot of Badlands specific parts.
2025 Badlands Sasquatch
It should be highlighted that this is only for non-Badlands trims, to bring them to the Badlands spec. If you have a Badlands already (and I suspect either OBX or BL with Sasquatch), this is not needed.
kenmitch
Ken
SoCal
2025 BS
lol....I added some clarification to the original post and thread title.
TheX
Randy
Austin TX
Yep, my OBX w/Sasquatch already has it.
hellb0y
Hellish
BS
This is perfect! One can buy a base BS that is already well equipped and slap the BL suspension on it for more ground clearance!
smcBronco
Sean
Ocean Shores, WA
Ford Bronco Outer Banks, Alfa Romeo 4C, Smart for two
Per the linked web site, this kit does not fit the 2025 Bronco Sport (which is what I have). I checked for 2023 and it again says it is not compatible. And it's out of stock so...
Ford Bronco Sport Ford Performance Badlands suspension kit for Non-Badlands trims 1759623163273-
kenmitch
Ken
SoCal
2025 BS
Not sure what's up with the stock or compatibility, but no matter what year is selected it says it isn't compatible. I'm guessing it's due to no current stock? I'm leaning towards this is a new offering and the initial supply hasn't arrived yet.
If you're interested in the kit, I'd suggest using the 'notify me' feature and then checking compatibility once it's back in stock.
Stircrazy
BC, Canada
2023 Bronco sport
for about the same price you can get the Billstein setup and get about 1.25" lift
