1.5l Drain Plug
DadofTim
Louis
Central Minnesota
2023 Outer Banks, 2013 Mustang Convertable
I have a bag of plugs and a tool to remove them easily. See my ad for miscellaneous items for sale. Trading the BS today for a Maverick.
BSBB4Les
Les
I'm there also. Have had many more days behind me than those ahead but just keep plugging along.
:wink: HaHa I got it! "Just keep PLUGGING along"! Good one wireman!
JHC14
Joel
2023 Bronco Sport, 2019 Ford Ranger Lariat
I just got my 23’ Bronco Sport Outer Banks Edition. Bought it from my son who got it new. Had the the oil changed at the Ford dealer. I do all this myself. Had not seen this oil plug set up before. Is this silly little plastics thing supposed to be replaced every time you change the oil? There is no way this is less expensive than a metal bolt.
I changed the oil yesterday. Do I need to worry about this?
cprcubed
Patrick
Parker, TX
No need to worry for a one-time reuse. Over time the o-ring could harden or be damaged causing leakage. Cheers!
Iamcanadian
Jason
Ontario Canada
Can anyone tell me if my 2025 Outer Banks would have a plastic plug thank you
In case you haven't found an answer yet, yes the 2025 with the 1.5 L definitely has the yellow plastic drain plug. I confirm this yesterday on my 2025 Big Bend
Gapbriel
Gabriel
Argentina
Bronco sport wildtrak ( badlands 2022 here in Argentina ) so … the service needs to change that every oil service ? I have this problem now
Ford Bronco Sport 1.5l Drain Plug IMG_9934
Ford Bronco Sport 1.5l Drain Plug IMG_9933
Ford Bronco Sport 1.5l Drain Plug IMG_9926
Ford Bronco Sport 1.5l Drain Plug IMG_9925
Ford Bronco Sport 1.5l Drain Plug IMG_9924
Ford Bronco Sport 1.5l Drain Plug IMG_9923
