Add Auto-wipers?
pantera155
pantera155
Pantera
Argentina
Bronco
@pantera155 is a good working rain sensor supposed to simply change its output voltage when rain is detected vs no rain detected? Basically being ”on” or “off”?
Yes, that's what I think. But in this case, the faulty sensor I bought never changes the voltage, and the infrared LEDs don't light up either.
It would be great if someone with a rain sensor could take a picture to see if we can see the light emitted by the infrared LED :)
Try looking at those LEDs using the camera on your iPhone (or maybe Android), iPhone can see some light spectrum beyond what may be visible to some
“ iPhones can see infrared (IR) light from sources like TV remotes or Face ID emitters, especially with the front camera which has weaker IR filters, appearing as purple/white flashes, but the main rear cameras filter most IR to keep colors accurate ”
“ infrared (IR) LEDs are generally invisible to the human eye because their wavelengths (700-1000nm+) are beyond our visible spectrum (380-700nm). However, powerful near-infrared (NIR) LEDs (around 850nm) can sometimes appear as a faint red glow if you stare directly at them, but they don't provide true visible illumination; they are seen by night vision cameras that detect these longer wavelengths, making them great for covert surveillance. “
