Rock chip repair
thegadgetfish
Michelle
Los Angeles
Has anyone tried filling in a rock chip yet? I have a small one all the way down to the metal on the side of my BS OB. Bought a paint pen off ebay, but not sure if it'll look alright. I thought the Cyber Orange was supposed to be a durable tri-coat!
Ford Bronco Sport Rock chip repair D3C24055-4FC8-490E-914A-303F47F7B2C8
Option 1...gently go for it, protect the metal with paint, it's a bronco...chicks dig scars just do your best to cover and smooth it with a primer base and fill. Mix properly and cover the boo boo.
Option 2 find a dent wizard/Ford body shop and let them do it professionally and you won't see it
Option 3 find a body shop who does good work cheaper than Ford.
thegadgetfish
thegadgetfish
Michelle
Los Angeles
Chicks dig scars but this puts a scar on my heart ?
Going to give diy a try and hope I don’t regret it.
The upside if you work small...a body shop can fix it if you can't. Just stay inside the lines. Apply multiple thin layers and build up to the surface depth. Don't try to block it all at once. good luck.
thegadgetfish
thegadgetfish
Michelle
Los Angeles
Don’t use a paint pen. It won’t look good. Dr color chip works great. I filled in two chips and you’d never be able to find them. Plenty of YouTube vids on how to use it.
https://drcolorchip.com/
Thank you, they currently don’t have the cyber orange color so I contacted them. Hoping to pick up a kit!
Kritas
Birmingham, AL
We used to "matchstick" paint to fill chips. Mid-year Corvettes would get a ton of small chips behind the rear wheels.
Clean the area to remove contaminants and use a matchstick or toothpick with paint on it to fill the chip. Finish as required.
rdc17
VA
Bronco Sport Badlands
Moltenburn
Denver
2022 BS BL w prem, 360, shelf. VW Arteon
This right here. Use a toothpick to apply paint from the pen. Do not use the pen directly. Start with a small fill. Allow to dry an hour or two. Go back in and small fill again. Wait. And then do it a third time. Best way to fill chips without professional equipment. Key is not to over apply on the first application.
thegadgetfish
thegadgetfish
Michelle
Los Angeles
Dr Colorchip came in. Very easy to use, and fast drying time. The color was a very flat yellow, so it is kind of obvious.
I have a paint pen too, and the color matches better, but it was very drippy and a pain to apply so I didn’t use it.
Ford Bronco Sport Rock chip repair CE2A365F-AEFC-4DCD-9F13-4D466414D51D
Cactusjk
Jeff
Woodland Hills, CA
Any more feedback on using Dr. Colorchip on Area 51? Assume it is a good match?
PaulOinMA
Paul
MA
Paintscratch.com
