- Thread starter
- #1
do you have any issues with rubbing pics please if you can looking to use these tires or another option if you have used one
Not BFG KO2's but... Link to thread here, post #10, best pics I have. Falken Wildpeak AT3W 245/65/17, all stock, no lift, no spacers, no mods, no rubbing, lock to lock.do you have any issues with rubbing pics please if you can looking to use these tires or another option if you have used one
thank youThey fit with no issue, so does the spare.
thank youNot BFG KO2's but... Link to thread here, post #10, best pics I have. Falken Wildpeak AT3W 245/65/17, all stock, no lift, no spacers, no mods, no rubbing, lock to lock.
Never been off road so I can't speak to articulation.
https://www.broncosportforum.com/forum/threads/looking-for-a-great-at-tire-for-my-bl.3901/#post-65508
looks great are the front tires closethank you
thank you i like the bfg tire i will not be doing off roading this so much was wondering if normal driving had any issuesBTW, a lift kit does not necessarily change whether a particular tire will rub or not. It just means that the suspension would have to articulate that much further to get to the point that it would rub (if at all). If you are planning to go off-road at all, I would not buy a tire that would rub at any articulation or lift/lowered height.
normal driving as per usual. a tad bit louder but nothing crazy at allthank you i like the bfg tire i will not be doing off roading this so much was wondering if normal driving had any issues
Thank you, I've been super curious if the spare would fit as well. ?They fit with no issue, so does the spare.
A little shove and it fit just fine. It touches the edges but doesn’t squeak over bumps so it’s a non-issue. It’s been about 10,000 miles or so for me. The only issue is for those without the factory tow package. The tray that covers the spare is a lower profile since it only has to cover a donut. With a full size spare, there is a gap with the floor piece that lifts up to access the spare compartment. Again, that is only an issue for those without a factory “full-size” spare.Thank you, I've been super curious if the spare would fit as well. ?
Perfect, I knew I made the right choice with the tow package.A little shove and it fit just fine. It touches the edges but doesn’t squeak over bumps so it’s a non-issue. It’s been about 10,000 miles or so for me. The only issue is for those without the factory tow package. The tray that covers the spare is a lower profile since it only has to cover a donut. With a full size spare, there is a gap with the floor piece that lifts up to access the spare compartment. Again, that is only an issue for those without a factory “full-size” spare.
