GulfCoastBronco
Topher
Corpus
I put on the seat jacker kit from Desert Does It. Really made a big diff in my driver seat, I feel like I'm planted in a bucket seat now not sitting on a leaning forward bench. I did the f150 kit which sits higher with three plates. Super easy install and great quality product.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220409_012913188
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220409_013237600
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220409_013350868
Just curious how tall you are? Only others I’ve seen doing this are well over 6ft but your description makes me wonder if it would change the feel for those of us under 6ft as well ?
dakman
I'm 6'1" around 200lbs. Just could not get comfy like I'm used to, this really changed the seat. I believe I raised it a little over a 1".
Digital_Synapse
Chris
San Antonio
The problem is getting all this stuff back in place without scratching paint. It's simply not a one-person job. However, on most jobs now that I'm older, the standing-sitting-need another tool routine wears me out.
Masking tape. Lots of it. That’s what we’ve been doing in the mustang world for ages now lol
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
The Process
Install driver side nerf brackets and tube - check
Wet down the underside with lanolin based undercoat -check
Replace compressed felt splash guard - standby
Need to modify guard to cooperate with brackets
Front bracket no prob, minor adjust
Middle bracket, worked exceptionally well
Rear bracket, ummm hold on
Needed to make cut in guard for bracket
How to address cut in guard
Did I tell you I love Kydex?
No?
Well I do!
Heat gun, shaping and forming to conform with guard
Couple holes and push pins later
Satisfaction complete
Maybe pics tomorrow
Just got the dinner bell........
thekingprawn
Dustin
Kingston, Wa
Custom rims, larger tires, lift, raptor fender molds with powder coating on the rivits, powder coated tow hooks, spare swing gate, tint, and relocate rear camera … lots of work!
Top three pics are before … last three after. Will take more soon ?
Ford Bronco Sport What did you do TO your Bronco Sport today? C7110018-1A98-40E8-BE60-43433184F919
Ford Bronco Sport What did you do TO your Bronco Sport today? 9AB3AFCE-92DF-4402-B0CD-16F9F85FACAB
Ford Bronco Sport What did you do TO your Bronco Sport today? DF25655C-79A4-45D2-9EDC-3169ABF6DCE7
Ford Bronco Sport What did you do TO your Bronco Sport today? 854A89AF-8EA2-4BF6-91F5-768398A3917E
Ford Bronco Sport What did you do TO your Bronco Sport today? F5ABF6FF-6D3B-4278-8F35-56B036A12033
Ford Bronco Sport What did you do TO your Bronco Sport today? 6E92A740-AB06-484C-95D0-78EF50539DEF
That looks fantastic.
Finally got around to installing the front and rear mud flaps.
The rears were a PITA. The fronts took less than 10 minutes each even with drilling three holes. Helps I suppose if you are ambidextrous when doing the backs or removing the tires. Backs also seem overly long to me but……
Major Kong
Major
Overly big mudflaps
Talk about mudflaps...........
1:35 min mark
:D
