Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Welp, learned not to hit the delete button on a post
So, here it goes again
Today I spent time on the bottom side of the BS
Might as well while I'm flat on my back doing nerf bars
Pop the rocker panel trim tabs
Insert Wool Wax catheter
Wet'er down good
PB Blaster Surface Shield saved for the more exposed to the elements sections
The hood struts went in effortlessly
Former use with struts on tool box lids always had one bad feature
May have changed over the years for the better though
Seems the retainer clips on the ball/socket connection would rust and fail
Made sure to give a generous helping of white grease in the socket
Ford Bronco Sport What did you do TO your Bronco Sport today? 1649444087166
GulfCoastBronco
Topher
Corpus
Installed the EGR hood deflector. WTF is it with the teeny plastic screw anchors that won't stay in the holes in the bottom of the hood by themselves?
Ford Bronco Sport What did you do TO your Bronco Sport today? egr deflector1
Dang not cool, screwing into the hood sounds intimidating. Looks good against the paint color. Any profile pics? Bar looks nice too, any lights or anything coming? Does the bar interfere with front license plate?
TakeTheBlack
Brad
Saint Louis USA
2022 Bronco Sport Outer Banks, 2020 Mazda CX-9
I replaced the pathetic carpet mats with the LIDAR scanned, perfect fit ones from WeatherTech. Here are some photos. It you have something that goes behind the pedals like this then I would like to see it. I say nothing is even close.
Ford Bronco Sport What did you do TO your Bronco Sport today? 986A7E22-05A5-4404-85E9-09AFA2C99559
Ford Bronco Sport What did you do TO your Bronco Sport today? 26689D0D-82BC-4089-8926-19D3FE1C4090
Ford Bronco Sport What did you do TO your Bronco Sport today? 0E87A7DD-26ED-427D-BCE1-F42F65993A24
Ford Bronco Sport What did you do TO your Bronco Sport today? 57BE89C9-E778-4C0E-BCFF-F0B9A019BC65
Wife wanted these from Costco you cut yourself. My keychain cost more than these.
Ford Bronco Sport What did you do TO your Bronco Sport today? F82E99E3-CD2E-4E96-898C-A3CEB1F20EE9
LilbroncoS
Brandon
2021 bronco sport
I replaced the pathetic carpet mats with the LIDAR scanned, perfect fit ones from Weather Texh. Here are some photos. It you have something that goes behind the pedals like this then I would like to see it. I say nothing is even close.
Bronco sport weather mats do ssme thing. I just dont like how stiff weathertech are.. to each his own
dakman
I put on the seat jacker kit from Desert Does It. Really made a big diff in my driver seat, I feel like I'm planted in a bucket seat now not sitting on a leaning forward bench. I did the f150 kit which sits higher with three plates. Super easy install and great quality product.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220409_012913188
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220409_013237600
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220409_013350868
