Can Someone Share Pictures of Their Bronco with Splash Guards
retiredguy
The $50/pair guards seem quite adequate (especially compared to the $250 ones). Do the $50 ones install with glue or screws? Are most of you doing the install or having the dealers do it?
All the mounting hardware is included. You need to drill 3 holes for the front flares. It is a combination of screws and push pins. Easy install and no need to remove wheels.
Whitenight
Charlie
Center of the Universe
Are people getting the factory ones that are almost $1000 (CAD), or going aftermarket and installing themselves? The factory option price seems crazy to me for what you're getting.
There are two versions of mud flaps available. The molded plastic version which costs around $50 per pair and then the Bushwacker rubber version that is around $250 per pair.
retiredguy
I have the $50 set and they are fine. No issues so far.
thekingprawn
Dustin
Kingston, Wa
Is there any noticeable benefit to splash guards or mostly just cosmetic?
Econoline
socal
I went with Weathertech for about $80. No regrets. .
Me too, they fit well and are easy to install. I do have a concern about the little "C" clips that secure the fronts, but so far so good.
MJE
Calgary, AB
My hope is they’ll actually help keep the car a little cleaner. But I live in an area with 6 months of dirty snow/slush so no matter what you do, the car is perpetually dirty.
cgparsons1983
Chris
Boise, Idaho
I got the cheap ones from Amazon, and the rear ones went on perfectly. You just pull out some plastic rivet looking things and then hold the guards in place while you re-attach them, so far so good. However, the front ones didn't seem to have a logical way to connect them without having to drill them in, and I didn't want to do that for cheap guards, so I left them off. I could have connected them without screws, but they would have fallen off pretty quickly.
https://www.amazon.com/gp/product/B09B3Y1Y7V/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I went with the standard Ford plastic ones. Fronts went on in less than 10 minutes. Back ones, not so much. In theory, they should be easier. In theory means your hands are really small or you are ambidextrous. Would have been faster taking the tires off IMHO. But…. they are now on as instructed.
ck122
chad
michigan
22 bronco sport 1950 chevy style line deluxe
screws and clip nuts only have to drill 3 holes into plastic on the front ones
