Rear side panels coming off.
Bdud
Brian
Chicago
Ford Bronco Sport Rear side panels coming off. PXL_20220326_185659062
Just noticed this today. It seems to be happening on both sides.
Is this happening to anyone else?
Bdud
Brian
Chicago
Lol yea as soon as I get home. It's the plastic black piece on the rear side window right after the rear door
AndyMac204
Andy
C pillar trim piece?
Bdud
Brian
Chicago
Yes
AndyMac204
Andy
hmmmm havent seen anything like that yet
AndyMac204
Andy
can you take a further back photo
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Ford Bronco Sport Rear side panels coming off. 1648323947829
My guess
water intrusion from missing sealant
water between panels freezes
expansion occurs
larger separation occurs allowing more water
freeze cycle re-occurs
crack widens
repeat cycle
Bdud
Brian
Chicago
Ford Bronco Sport Rear side panels coming off. PXL_20220326_195723224~2
Bdud
Brian
Chicago
My guess
expansion occurs
crack widens
repeat cycle
It looks like it's just taped on. It's not missing. I can push it back and it will stick for like 5 seconds then separate again. But yea your zoomed in pictures is what I was trying to capture.
Good evening. I'd like to take a closer look at what could be causing this issue with your Bronco's side panels. Could you please send over a private message with your VIN and the name/location of your local Ford dealer so I can look into this on my end?
Major Kong
Major
Ford Bronco Sport Rear side panels coming off. 1648326586548
I'd say some of the adhesive tape is missing
tape on close inspection looks to be two toned
guess I'm looking at 2 layered tape
one section of layered tape missing (?)
The stick effect you have when applying pressure is the sticky between layers
Bdud
Brian
Chicago
Either way it seems like other people are not having this issue. It's happening on both my c pillar trims. I'm just wondering if this is something I should take it to the dealer for.
BoxerBronco
Aaron
21 Ford Edge ST Line, 22 BS Badlands
Yes! It’s a new vehicle…also suggest messaging the Ford contact above!
