ALL 2.0 Engines after Feb 1, 2022 (Engine Cover)
bjbena
Barry
Escape SEL. EcoSport SES
cklapka
Colin
Rochester, NY
'22 Bronco Sport Badlands Hot Pepper Red
Those numbers stamped on parts are usually not the stock part numbers.
The actual part number is K2GZ-6A949-A.
Is anything else needed to mount the cover or is that all that has to be ordered?
Idontknow
Will
MN
Cross trek and grand caravan
Before these engine cover threads started, you couldn't have ever convinced me that such a meaningless item is important to so many.
If you tell people they canā€™t have something they will want it moreā€¦
Orin
Indiana
Yea just like when people buy expensive shiny rocks (diamonds ect.) and wear them on their body. OOooh look it sparkles in the light take my money! Even if the covers do nothing and is of no benefit it is a cosmetic item worth having.
M3H7363
2023 Maverick hybrid XLT
Expensive shiny rocks are worn out in view where people can see them. Engine covers are hidden under the hood. Nobody sees them.
Jumbo1953
Ohio
Ok. For those wanting an engine cover for a badlands I have a deal for you. I will sell you mine for $50,000 and throw in a 2021 Bronco Sport. ?
BigfootHunter
2021 BLBL KB
Not that I think itā€™s a huge issue, but being foam does it not have some NVH implications vis a vis the direct injection clicking? That being said our ā€˜21 BLBL has one, plebs.
The Shark
Cary, North Carolina
2022 BS BL, 2023 Bronco WT
Our '22 BS BL was built on 01/10/22 and delivered on 02/04/22, when we went to pick it up I was curious and took a look under the hood, no engine cover.
Steelbronco
Maryland
Possible cause of a starship explosion has been determined to most likely be the result of a missing engine bay cover. Although, this would have proved helpful, accurate temperature readings were not able to be retrieved from the control dials that seem to be modified.. Stay tuned for more breaking news.....(USS Bronco Off-World) ?
Ford Bronco Sport ALL 2.0 Engines after Feb 1, 2022 (Engine Cover) RemarkableUnfinishedFish-size_restricted
MJE
Calgary, AB
Surely the under hood insulation blanket wouldā€™ve put that out before it had a chance to get that far?! ?
Cactusjk
Jeff
Scottsdale, AZ
Part number for the 2.0 cover? Assume easy install with existing fasteners?
