Tire pressure - computer misreading
Alistar
Tony
CA
Mustang
Got my new BB couple of days ago and one of the first things I've noticed is the tires were overinflated (42 when the recommended is 33). So I took some air out with my manual inflator until dial reads 33-34. Check again the car and it says 37... Should I rely more on the dial than the computer? Can this get fixed for free with the warranty?
Thank you and happy new year's!
Ponyrider
Nadine
2021 Bronco Sport, BMW Z3
I believe most of us had our Sports delivered with high tire pressure. I know it says somewhere not to rely on the computer to check your tire pressure. Not sure if it's in the manual or if it tells you on the display.
Alistar
Alistar
Tony
CA
Mustang
Yes I think you're right. Do you know if this can be adjusted by Ford dealerships?
It used to happen with the Mustang too, every time I replaced tires they put way more pressure than recommended, feels like the want you to worn out those tires fast.
Ponyrider
Nadine
Sorry, I don't know if the dealership can adjust the computer. Yours does seem to read a bit higher than I would expect. Last time I checked, my tire pressure reading from the Sport was pretty close to what our hand gauge read.
fourthgear
florida
A lot has to do with temperature outside & when the readings were taken or if the BS was just driven. You can take out air when the Tires are cool ( proper condition when taking readings ) , if the Sun came out after the first reading , reading can change . I get different readings with the Sunny side , compared to the shady side of three Pounds , depending on out side air temp., its why I take readings before the Sun comes up from behind the Trees .
My readings from my digital air pressure gage is a little different then what the Dash board display reads , but by only a pound .
gcbroncosport
G
MA
Have a 3lbs difference b/w dash monitor and gauge (digital) from gas station... Then again, gas station gauge could be out of calibration. Manual did say do not go by dash.
Warpious
www.floracreekplace.com
My hand gage shows about 2 lbs less than the dash does and as mentioned the manual says do not go by dash. 40+ is for sure way too high but I wouldn't be super alarmed by being off by a pound or two.
rdc17
VA
BL+BL
You need to drive around a little after adding/removing air before to allow the sensors to pick up the change.
I have a pump with a digital readout and an analog air pressure gauge, I find that the TPMS is pretty much spot on with both.
Also, don't forget the pressure changes with temperature. You should be checking the pressure with the tires cold. If you check the dash indication just after your first start in the morning it will be lower than if you check it after driving for a bit, say after you get to the station to use the tire inflator there.
GulfCoastBronco
Topher
Corpus
I’ve seen pretty consistent higher inflation on the forum. Some even saying dealer inflating from 33 to 40 after oil change. I’ve had some TPMS error codes. I came across a video on here yesterday on how to recalibrate, did it last night and waiting to see if I have anymore issues.
