Type of fuel used on BS ?
Baby01
Linda
Curious as to what others are using for fuel type on their BS?
VirtualJMills
Jason
California, US
I'd assume most people are running 87 to 89 (RON+MON / 2) Octane unleaded fuel, and depending on where in the world they are, it might be 10% ethanol as well.
The folks who are towing or hill-climbing will likely be running 91 Octane to squeeze a bit more out of the engine (Ford uses at least two tuning curves for both the 1.5l I3t and 2.0l I4t engines).
Baby01
Baby01
Linda
Thank you!
87 Octane is supposed to be fine,.
The owners manual recommends premium for best performance.
Some people here were having fueling issues in high temperature climates and were told to run premium by their dealers.
I use premium in my Badlands and have not had any high temperature or any other fuel issues.
760Bronco
Palm Springs
I was using 91 during the summer. I was noticing a huge delay in power delivery to the point I brought it to the dealership.
Now that the weather is cooler, I’ve been running 87 without issue.
JEspey
2021 Bronco Sport BL; 2020 Jeep Wrangler Rubicon
87 in my 2.0 BL. 12,000 miles. Zero problems. If your engine doesn’t knock, 87 is fine. Ran it in my 350Z, two BMWs and four turbo Jeep Wranglers all with zero problems. Don’t fall into the 91 hype.
MaxVelocity
Montana
1970 Bronco
The only non-ethanol fuel we have around here is 91 octane, so that is what I run in all my vehicles. And the Bronco Sport Owner's Manual states 91 octane will also have better engine performance.
bjbena
Barry
Escape SEL. EcoSport SES
I'm with you. There is a 91 non-ethanol station on my way home from work for only 30 cents more a gallon so it makes sense.
Idontknow
Will
MN
Cross trek and grand caravan
Interesting. I hadn’t heard about the sport running two different fuel maps depending on the octane. But to clarify if a car tells you to use premium you should use what it calls for. A lot of forced induction vehicles (especially when we are talking about modded cars I know that’s not the case here) call for a higher octane to prevent pre detonation.
