Can't Select Sirius
Leeford
Lee
Ontario, Canada
bronco sport
The source selection will not let me select. I can get am/FM ok...It's nothing to do with subscription btw so no signal resend required. I,ve been in and out of the BO all day with no resolve.
thomasm23
Los Angeles Metro
Try resetting the head unit.
Press the volume and the next track buttons at the same time. Hold both down until the screen turns black and release.
Poolmanz Sport Bronco
Bruce
Castro Valley, CA
sites.google.com
'21 Bronco Sport FE Area 51
Need more details how you are connecting iPhone to Sync 3.
But you make sure the following:
1. Update to the latest Sync3 firmware
2. Check your USB port- some have had issues with wiring.
3. iPhone is updated to the latest iOS.
Leeford
Leeford
Lee
Ontario, Canada
bronco sport
went out to try your suggestion and guess what, it up and working now??? I will try you suggestion if this happens again. Thanks a bunch.
Group_44
Gary
Morrisville, Pa
Ford F150 Platinum,80 Triumph TR8, 69 Jag XKE 2+2
My sirius shutdown for a period , later found out it was due to a software auto-update being downloaded and installed. Worked fine ever since.
Flash
My Sirius only shut down during a microburst we had here a while back, but then Satellite TV shuts down during those also.
lej51201
Larry
Queensbury, NY
Mine has only done this once. Shutting off the vehicle, opening a door and thereby cycling the radio boot up solved it for me.
christopheru
The Great White North
I am excited for mine to go away. Then it cannot randomly turn on as I am driving pestering me with inanities.
Like depeche mode, I enjoy the silence.
Leeford
Leeford
Lee
Ontario, Canada
bronco sport
Mine as been acting up since I drove it off the lot in May. The Sirius doesn't work if you turn off the engine and turn it back on if off within 2 minutes or shorter, longer than that and it appears to work OK?
The dealer as tried;
1. updating the software,
2. rebooting,
3. changing out the module,
4. updating the software...again.
The dealer as sent in a video I took of the issue to the "engineers" ford. Waiting for a solution.
Leeford
Leeford
Lee
Ontario, Canada
bronco sport
lol...I did make the same reference to depeche mode to my wife as we where driving.
