Do you have a link to those tires? I am considering a lift and am looking at what tires peeps are going for. Especially interested in the sand performance when you get back out there!No issues driving over deep soft sand on TX coast. Had the continentals at stock psi but have upgraded to KO2 tires since then. I thought it performed better than gen 2 Raptor in the same sand environment. My guess was the lighter weight of the BS easily cut thru that sand.
Damn! Looks like that just caked into the treads. Makes me want to get some recovery boards…Got stuck good today in my BB. Had to get pulled out.
Ummm if you are stuck good enough, you need to do it, the goat mode will not get out...Has anyone got BS stuck good and then use sand mode to get out like crawl mode on Toyota?
Did you try recovery boards? Shovel? And air down to 15 psi?Got stuck good today in my BB. Had to get pulled out.
Usually down to 20 at least. This time I didn’t ?‍ I was at 30.Damn! Looks like that just caked into the treads. Makes me want to get some recovery boards…
What do you usually air down to when driving this kind of trail?
No recovery boards. Used a shovel. The shovel wasn’t enough. And I didn’t air down because I didn’t have an air compressor on me. My BB was fine at 30 psi for a while out there. I just slowed down too much in the wrong spot.Did you try recovery boards? Shovel? And air down to 15 psi?
Thank you, I didn’t think of that. I will definitely do that next time. On that topic of traction control, it’s odd how on the BB the traction control switch is on the console and not a traditional button. Thank you again!Every situation is different & going too slow in loose deep Sand will probably stick you every time in the BS. It's all about the feel , I use Low when Slow , take Traction control off . I looked at the screen when in Sand Mode & Traction Control was stated to be still on .
Thats interesting , I didn't know the BB has a different set up then the OB , I thought all models but the FE & BL were the same . The OB has the TC in the Settings on the display screen or what ever its called .Thank you, I didn’t think of that. I will definitely do that next time. On that topic of traction control, it’s odd how on the BB the traction control switch is on the console and not a traditional button. Thank you again!
That’s what I meant, my bad. It’s on the screen. And I played with it this morning. It comes on when I go into sand mode.Thats interesting , I didn't know the BB has a different set up then the OB , I thought all models but the FE & BL were the same . The OB has the TC in the Settings on the display screen or what ever its called .
