JamesT
James
Seattle
I just had a half-hour Q&A call with a Ford user experience rep. Just covering some of the basics about the Bronco Sport.
Going into the call, my main question for her was about antenna installation. She said, "I have to tell you that Ford does not support this, does not sell this. If you install anything electronic on your vehicle, it could void your warranty."
I pointed out to her that Ford has recommendations about antenna placement on the car. "Yes, I know. It is unfortunate that I have to say this."
Weird.
NavyBOFH
Alex
SE USA
21 Bronco Sport
Just bought some A-Pillar light mounts to use one as an antenna mount. Idea is to bore out the hole to accommodate an NMO mount and add the Comet SAR antenna to that spot.
Whichever side I don’t use will likely end up for sale on here for whoever wants to mirror-image my install.
Radios will be two Motorola XTL5000s, one VHF and one UHF on a special configuration running to a single handheld control head I will likely throw on a Proclip mount off the dash.
Ultraspaz
Ultraspaz
Minnesota
2021 Bronco Sport Badlands
Looking forward to seeing how it works and looks. Please share pictures of the installation.
JamesT
James
Seattle
On Monday, I received my a pillar brackets from Ford Ranger Lifts. Hoping to start the install this weekend which side are you going to use? I haven’t decided yet.
NavyBOFH
Alex
SE USA
21 Bronco Sport
I haven’t decided. I think passenger side will be where most antennas are located by factory, but. I might put it on the driver’s side if it disappears in the A-pillar blind spot well enough. I will just be “test fitting” with a Comet SBB5 I have sitting around since its a similar height to the SAR antenna I want to use. I am thinking of using one of those “thick material” NMO mounts instead of a UHF mount as long as I can get it to mount to the bracket with little drama.
Really in the end… getting coax and power in through the firewall and all the equipment mounted will be the harder part!
JamesT
James
Seattle
With inspiration from @NavyBOFH and the good quality, Bronco Sport-specific A-Pillar bracket from Ford Ranger Lifts, I have done the install and successfully Tx/Rx. Except for my own user errors, it could not have been simpler. I hope!
Below are my notes. I invite any and all critiques and suggestions.
The Ford rep said they could not warrantee this sort of thing because Ford does not provide mobile radio installs. That said, their documentation describes it.
Here are some lessons and observations.
  • I seems like some Ford engineer is a ham. There are nice little features to make this easy.
  • The BS Badlands has a completely rubberized floor. It seemed impossible to get at anything under the floor or behind the dash without ripping out a lot of stuff.
  • I took the lazy way and decided to route along the door rather than going through the firewall. There is a convenient bracket hole that seems made for routing cables. Of course, it is important to protect the cables and zip tie them so they don't move. Fortunately, there are handy holes that seem made for zip tying cables.
  • The weather stripping and trim are easy to remove and reinstall. And they are generous. There are also good channels right along the lip for running cables.
  • The bracket under the driver side seat seems tailor made for mounting a radio. There is generous room and little passage ways that make it easy to run the cables.
  • The A-Pillar bracket made this a breeze. I just had to ream it out to fit the antenna mount. I know what the manual says about mounting positions but I am hoping this A-pillar install will be ok. I know others have had different results. I guess time will tell if BS electronics are impacted.
  • It is important to use a grounding strap
  • Measure twice, cut once. The power cables were not long enough. But of course, I did not discover that until I had attached the connectors to the battery... had to start over.
  • Except for my own errors, the complete install was about an hour.
I am waiting to receive a ProClips Bronco Sport-specific mount so I can mount the control head.
Also: I have a leftover passenger-side ditch light bracket if anyone wants it.
Here are some photos.
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Bracket is just big enough for the antenna coax nut
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Cables routed behind weather stri
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Diamond antenna mounted to A Pillar bracket
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport 1627170589202
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Ford Ranger Lifts A Pillar bracket
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Grounding stra
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport routing through the bracket makes this easy
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport 1627170630768
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport You have to bend the rubber just a bit
NavyBOFH
Alex
SE USA
21 Bronco Sport
That looks great! My only thing is change is I’m going to find a way through the firewall one way or another. That is just how I tend to do the work even if it takes an extra hour.
I wish I knew this would become a thing sooner! Luckily someone on another forum mentioned they’d buy my unused bracket but I’m leaning towards driver’s side as well since I think it will be completely hidden from view while driving.
JamesT
James
Seattle
I appreciate your inspiration and look forward to seeing your install!
Because of the tight fits, and the nice bracket under driver side, I decided to go with driver side.
JamesT
James
Seattle
Used my Bronco Sport today to provide communication support for the Lake Ty triathlon. Bikes passed me and shouted they loved the Sport. “What a great looking rig!”
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport 90055E8C-0FD4-4634-83D9-9FD612D6EB8A
thesavo
savo
Albany NY
I took mine to the installer Wells communications in Troy NY for an estimate on a pair NMO 's added to the roof. Since space is limited, I also think a remote mountable unit is what I will add
I started a spreadsheet to help narrow down a good radio to install. I like the quad band TYT -TH9800D, and Yaesu FT-8900R. The Yaesu is discontinued . However I would then have to find a decent quad band antenna.
BrandModelBandsApprox
cost
Remote HeadProductionSoftwre program
TytTH-980010m, 6m, 2m, 70cm210yesdiscontinuedChirp
yaesuFT-8900R10m, 6m, 2m, 70cm500yes
yaesuFTM-300DR2m, 70cm500yes
yaesuFTM-6000R2m, 70cm330yes
AlincoDR735T/E2m, 70cm330yes
AlincoDR638HE2m, 70cmyes
AlincoDR-620 T/E2m, 70cmyesdiscontinued
IcomIC-2730A2m, 70cm340yes
IcomID-5100A2m, 70cm470yes
IcomIC-7100HF,6m, 2m, 70cm850yes
tytth-78002m, 70cmno?discontinued
tytth-79002m, 70cm215yes
AnyToneAT-5888UV2m, 70cm250no?
JamesT
James
Seattle
Even though discontinued, I managed to find an FT8900R and love it (I have one in another vehicle and wanted to have the same thing). Good luck!
thesavo
savo
Albany NY
We shall see. I know quad-band NMO Ham antennas exist. I have found much better talk about Larsen commerical and public safety antennas. They don't offer quad antennas. It might be better to separate it out.
Benanza
Ben
NJ
Trying to put transceiver/Antenna installation ideas in one location. Please move to appropriate place if needed.
Looking for location and wiring ideas/discussions/examples for both the radios and the antennas on our Bronco Sports.
Ford has some documentation on the subject that may be of use. Much of Fords info is based on the ARRL handbook concerning the routing of antennas and power leads.
Galvanic corrosion attachment will help anyone installing dissimilar metals to the body (antennas) to prevent corrosion if you start drilling the roof for your install.
UPDATE:
Trying to get this thread going so here is my install even if it may be temporary until I find a better solution.
Transceiver is a VGC VR-7500 Dual Band that you probably never heard of mounted in the depression under the drivers seat with velcro.
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Xcvr
It's an unusual radio in that the only front end controls are an on/off switch. Volume and channel selection is though the mic I mounted on the center console.
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Mike
The majority of the controls are by Bluetooth through a dedicated spare android phone that also monitors an OBD2 dongle. Still looking for a good spot to mount spare phone.
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Ham display
My antenna hasn't been delivered yet but the mount is a Diamond K9000LRM motorized mount I attached to the rear OEM luggage rack crossbar. Close to the Owners manual position 2 but not perfect. (NMO mount covered in silicon tape till UPS deliverers my antenna). Up/Down control for mount is next to microphone (see two pictures up). Power for antenna motor is though cigarette lighter power port for now but will be hard wired into fuse panel.
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Diamond motor mount
Power for the radio is directly wired to the battery by going through a grommet in the firewall directly behind the battery.
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Firewall
I was going to run the power leads to a 6 gang relay box I installed (in blue) but instead have the Pos. and Neg. going directly to the battery (yellow). Use caution if you decide to attach the Neg. lead to the body grounding post (right of the yellow line). With all the current going through all the electrical systems even with ignition off, you will get sparks if you loosen the body ground nut. I got sparks, all the light came on and I thought I shorted something out. I usually disconnect the Pos. terminal during electrical work but after reading the manual it appears some systems will require you recalibrate some of the systems if power is disconnected. I skipped the disconnect and it worked fine. I used an Automatic Power Off (APO3) box from APRS World LLC that turns on the radio power by sensing when the vehicle starts. It shuts off ten minutes after the engine is shut down. Just in case I forget to shut the radio off.
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Inked20210209_185631_LI
For the antenna coax I used 3 meters of RG 316. The small coax made in easy to run in the seam along the luggage rack and then down along the liftgate entering into the BS at the bottom.
Ford Bronco Sport Transceiver Installation thread  (Ham, CB, GMRS). Radio unit and antenna installation on Bronco Sport Route 2
I used Goop to hold the coax in position so it wouldn't get caught/pinched in any liftgate mechanisms. After the coax entered the rear of the BS I was able to hide the coax almost completely under interior molding to under the drivers seat.
My biggest concern's are coax type, a few hard 90 degree turns and running the coax parallel to a power lead for a few feet. Once I receive my antenna I'll see how bad I did with the SWR meter.
I'm a new Tech. licensee who has a lot to learn and I know some of the things I've done in this install are not best practice.
I hope others will post their Bronco Sport installs so we can all learn something and actually get some results when we google "Bronco Sport Ham radio installs".
Can I see abetter shot of how you have the trax installed on the seat
VirtualJMills
Jason
California, US
I'm assuming you mean 10/6/2/0.7 metre bands:
MFJ-1438, MOBILE, 10M/6M/2M/440 QUAD-BAND, NMO/SO
MFJ-1456 (quint-band, 2x HF + 6m/2m/0.7m, but SO-239 / PL-259 not NMO)
Comet UHV-4 (same band spread, but PL-259 not NMO)
Comet UHV-6 (more HF coverage, but PL-259 not NMO)
Diamond CR8900A (same band spread, but PL-259* not NMO)
*They say UHF, but they're using old nomenclature for where "U" in UHF started frequency-wise. It's a PL-259.
Diamond HV7A (same band spread, but PL-259 not NMO)
FWIW, there's a lot of negative data on using SO-239/PL-259 as structural connectors, and how poorly suited they are to this "additional" task particularly for high wind-load profile antennas. I can't speak to that, just offering some known-matches to your band coverage requirements.
I also haven't owned/worked any of these antennas personally.
