FordBroncoLifts
FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
Chasepoirier
Chase
Denver
Bronco Sport OB
they will fit but will rub at full lock turn. 255/65/17 would be a better choice. Just a little bit narrower size.
Great thanks. Saw on another post you mentioned putting together a video on how to make the mods to fit larger tires, is that coming out soon? Would be great to have
Btw your lift kit looks solid. Considering swapping out my RC one to yours because of the issues people have been having. Hopefully you can start shipping again soon
WarHorse1B
Alabama
Would love a more substantial front bumper! Especially to protect the radiator. I wish I had fabrication skill! Just cut off the black lower part and build steel from there! Then build out a tubuler bush guard to protect the front of the bronco.
FordBroncoLifts
FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
My kit will be back in stock in a couple weeks. I still need to make the video on where to trim. I have pics but a video would be better.
I will look into it. Problem is steel prices have gone up 200% since March.
WarHorse1B
Alabama
Yea everything has gone up a fuck ton!
Chasepoirier
Chase
Denver
Bronco Sport OB
In the meantime could you post those pictures? Would love to fit the larger rubber but Iā€™ve got limited fabrication skills so seeing step by step pictures would be awesome!
FordBroncoLifts
FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
Here are some pics.
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods B91FECAA-8B9C-4F88-8911-7D239A8A94F6
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 40C9BD3F-31CD-46E6-90A3-73CE0F56FD7D
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 5F73006B-91F6-4246-9D83-C70C9BA8A8CA
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 65952881-9E25-48EB-AF1B-12D40234A10E
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods AB891B18-7C3F-4D58-89A2-B426E7F64E25
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 2DDB193E-3FA6-4D55-82A8-16691BA6427D
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods B7AE4371-6D1B-4EEC-B65B-FE00739BA18E
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 35B82A77-3073-4220-A6D4-F597CBF64C14
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods F29553ED-7755-47E3-A56F-9AC46D0720C8
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 1B51EAC8-FB4E-4A8D-BA71-E767BBFCD478
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 31300066-68E2-4D7B-A594-F62F3463BCB5
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods BCE15BF6-2F52-4301-BFFB-D00E7E3F2962
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 76D9AE2D-17DC-45D6-8FAB-2F33F460CE3C
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 7AB3924C-5468-472E-9984-5A0FB831FCFD
Central Jersey
Mordechai
NJ
Bronco sport big Bend
@FordBroncoLifts Robbie
I will be buying your Base/big bend/outer banks 2ā€ lift kit when you have stock again.
Your website states :Recommended tire size is 245/65/17 or 245/65/18. Max tire sizes are 245/70/17, 255/75/17, 255/60/18, 245/65/18 with minor trimming of the Pinch weld on the firewall and minor trimming of plastic.
I have 18ā€ wheels and donā€™t want to trim anything. What tire size would you recommend?
I currently have 225/60/R18
I want to get the largest tires I can fit with my current wheels without rubbing or trimming anything.
what would you suggest as the best option from the list bellow based on fit and performance ? (by Performance I want the vehicle to be as stable as possible in sharp turns including at speeds I am not supposed to be driving at )
235/60/R18
235/65/R18
245/60/R18
24/65/R18
does 60 / 65 both work with my wheels ?
your lift kit + New Tires will be my first ever vehicle MOD . So I want to get the best tire size for performance without cutting the vehicle ( my dealerā€˜s body shop will do the install and a wheel alignment after the install )
Thanks in advance. I look forward to you getting the lift kit back in stock.
FordBroncoLifts
FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
235/60/R18
235/65/R18
245/60/R18
24/65/R18
Awesome Iā€™m just waiting on a steel shipment that will be here any day now. Then it will be up on the website and available for purchase. The perfect tire size would be a 245/60/18 that requires no Trimming and still looks great with the 2ā€ lift. Pics for similar tire comparison with lift.
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 486ECEBC-C651-4304-8A94-C5B2CABB7577
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 48806B3C-94ED-4FE8-9A45-51FF5EA9829B
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 36AC20FC-86EB-4DAC-8B3D-4A10630A4B60
Grove_LA
Colin
Southern California
2010 F150
Question. I see on your site that thereā€™s a 2ā€ lift that has spacers for both front and back and just a front spacer thatā€™s only 1-1/2ā€ only. Could you put only a 2ā€ spacer in the front?
FordBroncoLifts
FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
Yes you can just do front spacers.
