Anyone installing CB / HAM radio?
WarHorse1B
Alabama
As the title states anyone installed or planing to do comms?
Legin2000
Nigel
Put a GMRS transceiver in mine. Got a Midland MXT275 which has all of the controls in the handset. The radio is under the drivers seat. I ran the antenna wire along the rubber door seal, then out by the upper hinge to the hood. Power comes from the 12 volt outlet in the dash via an extension cable.
BobH
Bob
Rapid City, South Dakota
2006 Miata GT 97 f150 21 BS BL
Installed an Icom ID-5100 2m/70cm radio. Radio body is tucked under drivers seat. Control head uses an A-tach mount with magnetic holder. (see pics) the antenna is mag mounted until I get a SUV lip mount for the rear hatch. Power comes from the 12 lighter jack up front.
Ford Bronco Sport Anyone installing CB / HAM radio? 20210418_115018
Ford Bronco Sport Anyone installing CB / HAM radio? 20210429_140220
Ford Bronco Sport Anyone installing CB / HAM radio? IMG_3831 (2).JPG
lbjailer
Walter
Apple Valley, CA.
08 F150 Lariat 4X4, Bronco Sport First Edition
Have a Yaesu FTM400 kept in a plastic ammo can. Drilled out holes for cables etc. Kept portable as it is also my base station. Had stereo shop run power wire through the firewall. Also have a portable Midland CB that can be used as walkie or connected to power point with external antenna.
WarHorse1B
WarHorse1B
Alabama
Awesome did y’all have to tune the antenna?
