Does Towing Package come with full-size spare tire?
Sergeant Gearhead
Missouri
Hi, guys! SG here.
I have a question about the towing package on the Bronco Sport. In the b&p it says that it has a full-size spare tire included. I've looked everywhere to see if this is true or not, but so far nothing. Is this true?
wiyeti
Corey
BS Outer Banks
Hi, guys! SG here.
My Outer Banks has full size spare. I believe all factory orders with hitch package have full size.
Dustymedic
Bob
Central Ohio
2021 Rapid Red Bronco Sport OB
When my dealer entered the specs for my order; the sales manager said that when you enter the tow package, mini spare disappears from one column and full sized spare appears in another. I ordered the tow package mostly to get the full size spare.
I'd like to hear the cost on the factory installed tow package WITH the full size spare so I can compare with my future add on cost to my base model.
You know, tow rig, hitch, wireing etc, with out spare..
pixlpush
Portland, OR
I may be wrong but I believe the "full Size" spare is the same diameter as the stock tires but still narrower. Still better than a mini spare but not exactly the same as the main tires. I don't have mine yet but I seem to remember this when checking out a badlands with the tow package at the dealer.
Sergeant Gearhead
Sergeant Gearhead
Missouri
Thanks for the confirmation! I'm just wondering because I think it's better to avoid the mini spares (my dad calls them donut tires) and instead look for a full-size instead since they're bigger (duh!) and last longer.
Dustymedic
Bob
Central Ohio
The one I looked at had what appeared to be a steel wheel and a slightly narrower tire. But it beats a doughnut when it's 10:00 P.M. and you're 300 miles from home.
Sergeant Gearhead
Sergeant Gearhead
Missouri
Exactly. Also, another downside to having to use a donut tire is that you have to drive at a slower speed than usual because they expect you to go straight to a tire store to get it fixed.
Dustymedic
Bob
Central Ohio
When Chevy started using those back in the late 70s, the rule was no more than 40 MPH for no further than 40 miles
realworld51
On vehicles with 18” wheels/tires (std Outer Banks, opt Big Bend) the ‘full size spare’ is still 17” wheel/tire.
AV99GT
2021 BS
Our Outer Banks with Tow package has a 225/65-17 Spare, and it was 495 sticker price. I looked under the vehicle and the hitch is all one piece with what is the Bumper Beam. also note the rear Fascia (bumper plastic) is different from the non-tow packages.
PapaHotel
Paul
2020 Explorer 2019 Ecosport
Also, the full-sized spares (They are wider) have a higher floor, so a bit reduced cargo capacity.
jsus
US
hmm
Being a Bronco (Sport), it's not a temporary spare (e.g. a Maxxis unit). At least on a Big Bend, it's a ContiProContact just like the other 4, though on a steel wheel. So it's a proper wheel and tire, but may not match the larger wheels/tires depending on configuration.
FirsandFire
Ken
HV, NY
Yes the Factory tow package has a full-size spare tire. As mentioned above the floor of the cargo area is slightly raised. There is a good amount of room in there as well. Mine was the exact same size, brand and model as the 4 that were on the car from factory. Also, with the factory tow option and the larger "floor cover" a larger spare can be fit if you choose to change your tires to a different size. The attached photo is a 245-65-17 (stock size was 225-65-17) I do not think a larger diameter would fit in the factory spare location without some serious modifications.
Ford Bronco Sport Does Towing Package come with full-size spare tire? tempImagecby5Gl
