- First Name
- Sher
- Joined
- Jan 29, 2021
- Threads
- 2
- Messages
- 10
- Reaction score
- 33
- Location
- South Alabama
- Vehicle(s)
- Ford Escape, F-150
- Thread starter
- #16
Standard wheel and tire is Pirelli Scorpion tires.Don't these come with Falken Wildpeaks?
My understanding is that Badlands is about an inch taller.I wonder if the Outer Banks is the exact same height as a Bad Lands or FE stock? Or do they have a more “factory” lifted suspension than the OB??
I think FE and Badlands have slightly more ground clearance. Supposedly 1 inch taller.I wonder if the Outer Banks is the exact same height as a Bad Lands or FE stock? Or do they have a more “factory” lifted suspension than the OB??
looks great BTW!
Yes, the optional tires are 29.1" Falken Wildpeaks (235/65R17). So those 245 are only about .4" more so ground clearance would go from 8.8" to 9.0".Don't these come with Falken Wildpeaks?
Yes. 0.5 inches taller and 0.3 inches wider on paper. Some tires are actually smaller or bigger and don't run true to size.Yes, the optional tires are 29.1" Falken Wildpeaks (235/65R17). So those 245 are only about .4" more so ground clearance would go from 8.8" to 9.0".
The optional Wildpeaks are actually 29.1" tall and the 245 KO2's are 29.5" according to the tiresize.com website.Yes. 0.5 inches taller and 0.3 inches wider on paper. Some tires are actually smaller or bigger and don't run true to size.
I thought the 245's would be wider than that, compared to the 235's..that seems like it would be hardly noticeable.Yes. 0.5 inches taller and 0.3 inches wider on paper. Some tires are actually smaller or bigger and don't run true to size.
What trim do you have?I got the same thing from Discount Tire.This size was "RED FLAG" in their system,wouldn't do it.So,I got Toyo 235/45 instead,very happy with the look.
Base? Big bend? Ob? Bad land?And who put those tires on? Costco test fitted one on my stock FE and said it touched the carpet fender well liner at full crank, so they wouldn't put them on ?
FE, First Edition. Maybe Costco is just over-cautious. Looks like people are starting to put them on without any issues.Base? Big bend? Ob? Bad land?
For the base, big bend and ob there a lift kit to 1.5... maybe will fit with it....
Hey Ken, I saw the deal you mentioned on that FB post, can you share which dealer that was?There is a guy who put 245/70/17 on his Base Sport - Pictures can be seen here (Note: link to FB Group)
Thanks !!Cost was around $1,000. Can be done for less I think. If you take it to an independent shop.
Big BendWhat trim do you have?
